concerned about compression ratio
Old Oct 30, 2003 | 01:38 PM
neverenough's Avatar
neverenough
Yup, Torky2, I feel the same way. My motor had such low miles when I started to work on it I didn't even touch the valves or seats.
Old Nov 10, 2003 | 03:02 AM
monaro-azz's Avatar
monaro-azz
I know it's a little off track guys but whats your average octane in the states? over here in oz it's 95-96 octane normal and 98-99 octane premium..
Old Nov 10, 2003 | 11:19 AM
b9inger's Avatar
b9inger
Here in Georgia, 93 octane is as good as it gets.
Where is "oz"?
Old Nov 10, 2003 | 11:49 AM
Torky2's Avatar
Torky2
93 here. Your octane rating method may be different in the land down under (oh no, now I'm humming that song!). IIRC, the present US Octane rating system is Reseach + Motor, divided by 2. In other words, average the numbers that the two methods give.
Didn't oz have monkey troubles?
Old Nov 10, 2003 | 12:09 PM
georgedavila's Avatar
georgedavila
91 octane in Nevada. 100 octane retails for $4/ga, 100 octane avgas $2/ga.
Old Nov 10, 2003 | 10:50 PM
monaro-azz's Avatar
monaro-azz
Oz is "the land down under"or as my friends call it "god's country" australia.
So torky you've heard about the politicians in australia then. lol
I'm pretty sure we run the same formula for octane as the US.(not 100% sure though)
Aaron,
Old Nov 10, 2003 | 11:29 PM
74crwcb429hibPS4spd's Avatar
74crwcb429hibPS4spd
I am running 9.5 cr with mild port, polish and gasket match, stock exhaust and Motorcraft carb. I have been able to run on 87 Octane but had to retard a fair amount to only get slight pinging when lugged down.
Running on premium(91 Octane) it difinately runs very smooth and strong.
I can only break the tires loose in 2nd gear(A 4 spd NP with 4:10s)
I am getting a back fire(I think through the carb not the tail pipe) and will be putting in new points and setting the dwell next weekend. This backfire occurs sometimes when the foot goes to the floor and the secondaries kick in. The secondaries don't always kick in smooth, sometimes faulter alot, once in a while a backfire.
Any thoughts here?
Old Nov 11, 2003 | 08:34 AM
gdavis2265's Avatar
gdavis2265
That carb might be running a little lean
Old Nov 11, 2003 | 10:25 AM
74crwcb429hibPS4spd
Thx Glenn
Old Nov 12, 2003 | 02:17 PM
wtroger's Avatar
wtroger
You need to figure your altitude in to this deal also. At sea level a 10.5 to 1 engine will have problems with detonation on 91/93 octane fuel at 4000 ft or higher it will run on 87 octane no knock. I don't know the exact formula but for every so many feet of altitude you lose 1/2 point of effective compression. As for lead substitue. If an engine has ever had leaded fuel ran in it. The residual lead will protect the valve seats indefinitely. If an engine is not constantly ran under heavy load it will take a long long time before any valve seat damage to show up. And any Ford engine built in 1972 or later was designed to run on low/no lead fuel IE: harden valve seats
Old Nov 17, 2003 | 09:46 AM
b9inger's Avatar
b9inger
I'm at 808 feet ASL. I wonder if 93 octane will be enough to handle the compression?............
Old Dec 18, 2003 | 05:21 AM
Johnny Bravo's Avatar
Johnny Bravo
Try Canada...... Reg. unleaded 87 octane is Nearly $3.50 a gallon........you don't want to know what the 94 octane stuff is!
Old Dec 18, 2003 | 11:09 PM
  #28
74crwcb429hibPS4spd
1.46 this week this side of the border for what is suppose to be 87 OCt
351Cleveland C4
13
Mar 7, 2014 06:59 PM
nothercrash
18
Mar 11, 2011 05:41 PM
66_in_ky
Aug 22, 2007 10:16 PM
ivanvel
Aug 26, 2005 05:39 PM
The Vagabond
Dec 27, 2002 05:58 PM
