2004 f150 maintenance
Old Mar 1, 2021 | 07:17 PM
Demonfear's Avatar
Demonfear
Just picked up a 2004 f150 fx4 with 194k miles. From what I can tell everything seems to be running great, including no noise from the engine. I'd like to try and keep the engine issues I've heard about from creeping up if possible such as cam phasers and timing chain adjusters. I typically have ran full synthetic in my vehicles with 5k mile OCI. I found my local hardware store carries Motorcraft semi synthetic that I figured I'd change every 3-4k miles which would be about every 2 months. Wondering if there is something else I should be doing?
Old Mar 1, 2021 | 07:23 PM
muhford's Avatar
muhford
Do you have the 2 valve or the 3 valve?
Old Mar 1, 2021 | 08:00 PM
Demonfear's Avatar
Demonfear
3 valve 5.4
Old Mar 2, 2021 | 08:02 AM
WWR's Avatar
WWR
Well I guess I'd take a good luck at the FPDM above the spare tire for corrosion and to see if standoffs have already been fitted.
Also if the shifter is the least bit weird make sure the cable isn't burning through at the exhaust.
Change the trans fluid and consider installing a pan with a drain plug while it's down.
Use 5W-30 motor oil
A.O.
2004 - 2008 F150
Sep 13, 2017 03:04 PM
chris79#1
2004 - 2008 F150
Mar 19, 2015 11:58 AM
MarksA-C
2004 - 2008 F150
27
Apr 29, 2012 09:26 AM
shorebird
2004 - 2008 F150
Sep 17, 2003 09:24 AM
