My new amp is making my battery volts jump around when the bass hits. Will a capasitor help, or a new alternator, or both? Oh yeah, it mainly when it's idling, fine when the RPMs are higher-.
Originally posted by No_BS My new amp is making my battery volts jump around when the bass hits. Will a capasitor help, or a new alternator, or both? Oh yeah, it mainly when it's idling, fine when the RPMs are higher-.
Both would help, but given the situation you describe (only on occasional hard deep bass hits), it sounds like what you need most is a capacitor.
For the money it would cost for a decent cap ($80-$120,) you could buy a damn good battery instead. After all, a cap is just a battery, and a very small, limited use one at that.
By upgrading your existing battery to a Red Top, Interstate Megatron, Exide spiral cell or similar; you will not only improve your stereo's ability to hit those low notes effectively; you'll be upgrading your entire vehicle's electrical system at the same time.
BUT; before even doing this, I would suggest spending $10-15 on some hi strand count 2 or 4 AWG and upgrade your alternator> battery + lead, your battery> chassis ground, and your engine> chassis ground. Many times, these small (but very important) steps will solve your problem right there. Good luck.
a cap is a little like a battery in the fact that it hold power. the difference is it can release the power much faster than a battery. that is why when you hit hard bass note the lights flash or dim. the battery can provide power fast enogh for the amp so it pulls it from the alternater. over all a battery is better for current but not for fast pulls of current. all so with a new battery you will need 4ga wire or biger, three fuse holders. one at the front and two at the back, as well as a high amp relay or battery isolater.
add all that up and a cap is better for his problem and his pocket.
Any suggestions on what cap. to get, what else do I need? I really didn't get all that big of an amp, it's only 150wx2, I have 8 guage power and ground and am running 2 10" subs. It hits very hard and I like it. And oh yeah, I'm thinking that this is the same problem but want to make sure: when I use the bass boost (I know, it's bad, but am willing to blow my crap subs) the amp will completely shut off. It comes back on in a few seconds after I turn the boost off. Is this becasue of the voltage dropping too low also? In case your wondering it has remote bass boost, which will be really cool once I figure out where to mount it (any suggestions?).
and to that i disagree as well
Red tops help, but they dont eliminate lights dimming. I have a brand new red top battery and my lights still dim. Red Tops simply store more juice, hence, longer playing time. less dead batteries... a capacitor is what he needs.
also, as to what brand capacitor to buy, I've been told that ultimately, there is only 2 companies who make car audio capacitors. The retail companys just buy them and slap their name on them. In my mind, they're all the same.
Id second (or third, not sure) the vote on no cap, at least for now. Try upgrading the stock wiring ie bat negative to frame/engine block and batt positive to alternator. doing this on my explorer got rid of about 99% of my dimming and i prolly have about 3 times that much in amp wattage running. By the way what kind of vehicle is it?
just about any cap will work. the best way to check for a good cap is weight. the more it weighs the more electrolite stuffing it has. so the more power it can hold.
i have 4 guage wire running to my amp. You have an interesting idea there, rerunning wires to the starter and frame. I might try that. I still think a capacitor is easier But good idea!
my suggestion, though it is more on an general electrical rather than stereo system basis, is to re-wire your alternator and ground wires first. That is a good idea any time you are going to put a heavy drain on the electrical system. If that doesn't solve the problem, then look into a capacitor. Plus, what is the total RMS wattage drain on your amp, compared to the output of your alternator? if the amp is drawing more than the alternator can produce, look at getting a HO alternator (100-120 amps and higher). oh, just in case you don't know the formula
watts = amps x volts.
Did you read what the original poster said about his amp? It's only 300W. Even at idle, his electrical system should be able to cover that easy, along with whatever else he's running. (Unless, of course, he's idling *really* low.) It sounds to me like his electrical system isn't deficient; it's *defective.*
I agree with Geezer...at least check the wiring around the alternator and its ground. The wiring to the amp is obviously OK, since it's capable of delivering enough juice to cause his meters to jump.
The other thing to consider is whether the voltmeter(s) is delivering a reliable measurement. I doubt that the stock meter (assuming that's what he has) was designed for large, cat-quick fluctuations in current like he may be experiencing. If this is the only symptom, there may be no problem at all...
I run a 300w amp in my car, and with a new battery in it, it will dim the lights at idle. My car idles at about 800. there is nothing at all wrong with my electrical system.
