Need help obs fam
Old Feb 28, 2021 | 03:08 PM
Javy73's Avatar
Javy73
Need help obs fam
I got a Belltech 2-4 drop kit with coils and SP shocks for my 95 f150. Got it aligned but my front wheels aren't looking straight as they should. It drives straight, not pulling to either side. I just don't like my wheels looking slightly slanted. Has anyone else experienced this problem b4?
Thanks in advance fam.✌
Old Feb 28, 2021 | 03:23 PM
ViperGreg's Avatar
ViperGreg
Slanted in which direction?
Old Feb 28, 2021 | 03:41 PM
Javy73's Avatar
Javy73
Slightly inward up top
Old Feb 28, 2021 | 05:08 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Did you get the adjustable caster/camber bushing's put in, it will lay in at top, some, got a front/head on pic?
Old Feb 28, 2021 | 07:05 PM
Javy73's Avatar
Javy73
No I didn't know I had to change them but the shop that did the alignment said it wouldn't make a difference if I change the cambers. Its mostly the passenger side.
Old Feb 28, 2021 | 07:20 PM
mitchr97's Avatar
mitchr97
Did you go to a shop with a hunter alignment machine? Did you get a print out of your alignment? If they're saying it's within spec and didn't give you a print out, I'd go to another shop and have it checked (preferably one with a hunter alignment machine). They are supposed to be in towards the top slightly.
Old Feb 28, 2021 | 07:44 PM
Kenneth P's Avatar
Kenneth P
Good looking truck.Would love to drop mine like that .Hoping you get front wheels straightened out.
Old Feb 28, 2021 | 07:52 PM
Javy73's Avatar
Javy73
Ok thanks fellas appreciate the feedback.👍Are any of u guys familiar with DJM I-Beams? Will those fix my problem?
Old Feb 28, 2021 | 08:07 PM
mitchr97's Avatar
mitchr97
I don't unfortunately, but I'm sure there are others that will chine in!
Old Mar 1, 2021 | 10:21 AM
Beto Gray's Avatar
Beto Gray
So it definitely looks like you're camber bushing is out of whack. Like others have said definitely go to a place with a hunter alignment and get a printout. I know when I put new Springs on my truck they were the opposite, the top was out further than the bottom. If that makes any sense... LOL. To fix the camber issue, it's pretty simple. Unloosen the bolt that holds the bushing tight, and then get the appropriate wrench on the bushing and turn it one way or the other till the wheel is straight up and down. Though I would probably recommend going to the shop, being the liability issues LOL. Yours is definitely extreme, but you do want it to sit slightly like that.
Old Mar 1, 2021 | 10:25 AM
Beto Gray's Avatar
Beto Gray
Oh and on the DJM beams, I'm not positive, but being a 2-inch drop you might be able to just get away with adjusting your camber bushing. I know from Moog you can get one that will allow up to a 3 degree change. I do know that when guys drop these trucks way down you have to either get your high beams cut and re-welded or get different beams to compensate with the camber issue.
Old Mar 1, 2021 | 05:53 PM
Scndsin's Avatar
Scndsin
No first hand experience, just several years of reading about dropping a twin I-beam truck on this forum...
Any type of drop on the front other than with lowering I beams will result in some sort of lean. You can't beat the geometry of a single arc with short springs.
The pivot point is going to be same & it's like driving around with 2- 200lbs friends sitting on the hood.
Jake Woolley
Feb 9, 2021 11:06 PM
RCR70ss
Apr 4, 2019 06:01 AM
56FordGal
All Other Items for Sale
Aug 7, 2016 06:05 AM
2007stlFX2
2004 - 2008 F150
Mar 22, 2013 02:57 PM
