Sponsored by: Real Truck
How does intake manifold affect fuel trims
Old Feb 28, 2021 | 10:18 AM
1Truck's Avatar
1Truck
How would replacing an intake manifold cause negative long term fuel trims on both banks?
2001 f250 with 2v 5.4 triton
Old Feb 28, 2021 | 10:35 AM
Conanski's Avatar
Conanski
Why was the intake manifold replaced?
The PCM builds up adjustments to engine conditions over time so if the intake is malfunctioning in some way this can affect airflow through the motor which then affects fuel trims.
The new intake fixes whatever was wrong with the old one so now the computer begins to reverse the adjustments that were built-up.
Old Feb 28, 2021 | 10:40 AM
1Truck's Avatar
1Truck
Honestly, the only reason it was replaced was because I had it apart to repair a coolant leak. The older intake manifold has a smaller bottom and is all plastic. The newer one has threaded inserts for fuel rail and throttle body. I just don't understand how a larger manifold would create negative long term fuel trim
Old Feb 28, 2021 | 10:42 AM
1Truck's Avatar
1Truck
Should I reset the ecu?
1Truck
Feb 28, 2021 09:43 PM
ibuzzard
Jun 22, 2020 10:59 PM
black_truck
Aug 19, 2004 09:32 PM
