Squirrels chewed/ severe wires...
Old Feb 27, 2021 | 08:14 PM
TerdFerguson's Avatar
TerdFerguson
Edit to add: 2019 F250 SRW 4WD 6.2L Gas
I've been having an evap code and gas cap message for a month or so. Replaced gas cap, no difference (switched back to old one after a week). Figured it was something minor that I could get taken care of any time in the next month. Opened hood today after having a squirrel suspicion (long story) and noticed that a giant nest had been recently built, and in cleaning out the nest, saw that a wire going (thru a connector) into something to do with post-filter intake air was chewed completely through. But I'm looking for an ID as to what this wire is. There are two wires that emerge from the cloth wrap and go into the plastic clip. From the pic, you can see that the little buttholes chewed it off close enough to the clip that I can't simply splice the wire back together.
Been searching for diagrams, schematics, etc., to try and see what this wire is going to in the air intake manifold (at least I think it's the intake manifold - it is in the center, back towards the firewall, downstream of air filter). Anyone have any idea what this is, and perhaps more importantly, does it have anything to do with my evap issue? I'll post better photos if necessary. These were just the ones that I snapped today as I was tearing the nest out.
Thanks for taking the time to read!
Chewed-through wire
In situ
Old Feb 27, 2021 | 08:17 PM
TerdFerguson
Shoot...
Old Feb 27, 2021 | 09:03 PM
Just Chilling's Avatar
Just Chilling
Solder it and use liquid electric tape to insulate it , it’ll be fine
Old Feb 27, 2021 | 09:07 PM
TerdFerguson
I appreciate the help!
Is there a tip for how to do this when there is only 2mm of wire coming from the connector clip?
Old Feb 27, 2021 | 09:14 PM
Just Chilling
Use utility knife to scrape insulation off wire in plug then flux and tin wire in plug first then do the same for harness on truck side after all 4 wires are tinned and solder is sticking good hold them together heat them up one pair at a time they will glue together and done!! About a ten minute job and back on road again.
Old Feb 27, 2021 | 09:50 PM
TerdFerguson
Awesome. I'll see how far o get tomorrow! Seriously, thanks for the help.
Old Feb 28, 2021 | 06:37 AM
Crotchety Ford truck only's Avatar
Chewed-through wire
In situ
You should be able to release the pins from the plastic connector and put a new wire on the pin, or buy a new connector. It's a two wire connector so easier than one with more.
One would think that was an actuator that connected the vacuum to maybe the vapor line from tank, especially where you have a code from that system.
Old Feb 28, 2021 | 08:03 AM
TerdFerguson
Yeah I was hoping that this would fix the evap stuff too! Stands to reason...
Here's another picture...
Old Feb 28, 2021 | 08:12 AM
cpro24's Avatar
cpro24
I have had many issues with squirrels and mice in the past so I started spraying engine areas with a peppermint concentrate it has done a good job of keeping the rodents away
Old Feb 28, 2021 | 08:16 AM
TerdFerguson
I'm definitely going to try some kind of spray like that. Nature, man. Sucks sometimes.
Old Feb 28, 2021 | 08:49 AM
burnbothends's Avatar
burnbothends
That's very annoying for sure....
Had issue with mice nesting in vehicle in carport....tossed a bag of mothballs on ground under vehicle and a couple rubber toy snakes a 20" or so long and no more mice. Still working over a year later... squirrels are smart.....maybe a bigger snake? Lol.
Hope you get the varmints!
Old Feb 28, 2021 | 09:08 AM
TerdFerguson
Haha thanks! That's a clever solution. I'll keep those in mind. First option might be some grilled squirrels xD.
I'm actually looking for a pigtail at the moment, and you'd think that with the number on the plug, it would be simple to find a replacement, but... not really.
Does anyone have a line on how to find parts like this? The plug has E02FL-RS on it, and this returns some results, but nothing that matches exactly.
Old Feb 28, 2021 | 09:44 AM
burnbothends
Try this....
https://parts.ford.com/content/dam/f...il%20Final.pdf
It's a start... good luck
Old Feb 28, 2021 | 09:51 AM
Or a baited door trap.
Old Feb 28, 2021 | 10:27 AM
TerdFerguson
Try this....
Whoa that is an awesome guide. Thank you for posting this! I don't see it, but I'm only on my third scan through 😂
