Misfire Problem
Old Mar 3, 2021 | 05:09 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Have you checked what timing is set at, with him, swapping in new heads, maybe he got timing off also, while you check fuel pressure, and yes firing order is 1-3-7-2-6-5-4-8, and that is counter clockwise, and passenger side is cylinders 1-2-3-4, driver side is 5-6-7-8, just to make sure.
Old Mar 3, 2021 | 05:38 PM
Joseph Priori's Avatar
Joseph Priori
how do you check timing I thought that they were automatic. The long block was redone by a machine shop so I think that the distributer was just installed wrong. It’s a cheap aftermarket parts store one too so I’m sure it doesn’t help. How do I check the timing and what risks are involved with changing the distributor. Also, is there a way to check each injector is working properly?
1966F100SC
18
Jan 22, 2021 02:02 PM
CamoF-250
Mar 24, 2020 05:18 AM
NateTheGreat
Sep 6, 2016 06:59 PM
deljac
Aug 25, 2011 12:20 PM
jessfactor
Apr 16, 2004 09:55 PM
