Aerostar Ford Aerostar
power steering pump replacement
Old Oct 27, 2003 | 08:21 AM
wobndob's Avatar
wobndob
Help! I need to replace my power steering pump on my 94 Aerostar. Has anyone perfomed this task before? It appears that the pulley has to come off the pump before it can be removed from the engine. Any tips?
Thanks,
Old Oct 27, 2003 | 08:46 AM
mwkobe's Avatar
mwkobe
goto this link
http://www.cybrrpartspro.com/Chilton...24CH08_41.html
Old Oct 27, 2003 | 10:28 AM
mistarman's Avatar
mistarman
You don't describe the problem with the pump. I once thought mine needed replaced due to alot of noise coming from the area of the pump. Upon investigating further, it turned out to be the idler pulley bearing.
Old Oct 28, 2003 | 11:04 AM
wobndob's Avatar
wobndob
I have belt squeak and chirpping from the pwr steering pump. I had previous problems and tried to remove the pulley using "improvised tooling" . I later discovered the belt had split causing the noise, BUT in the process of trying to remove the pulley with the wrong tools I might have bent the shaft. I used to have noise only when cold, now I have the noise all the time!
