Modular V10 (6.8l)
Help..
Old Feb 26, 2021 | 12:52 PM
twesley's Avatar
twesley
Help..
Crank no start 2017 6.8 E-350. Had battery disconnected over the winter months and now will not fire. Checked fuel pump relay,pcm relay and other fuses and relays. Check engine light comes on with key on tach moves when cranking. Had a spare coil and plug from a different e 350 and shows no spark.
Old Feb 27, 2021 | 05:26 AM
JWA's Avatar
JWA
This might be related to the crankshaft position sensor. If the van sat without being started its possible a rodent may have chewed into the wiring.
Old Feb 27, 2021 | 11:46 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Ditto on this. Also, with the key on, check for +12V between the coils (one wire should be red with a tracer, that should be +12) and ground. If you don't have +12 there, it won't fire the coils. Same thing for the injectors.
cabloom300
Feb 12, 2014 10:16 PM
SeannyBoy84
Dec 17, 2009 06:56 PM
7.3mule
Dec 20, 2008 08:13 AM
unisphere
1983 - 2012 Ranger & B-Series
Nov 2, 2008 07:34 AM
Crzdir
Jan 23, 2007 08:21 PM
