Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1979 C900 No start
Old Feb 25, 2021 | 06:46 AM
Andy Martin's Avatar
Andy Martin
Unhappy 1979 C900 No start
After a new starter; new coil , and starter solenoid I still get no crank. I have posted pictures on how it looks now. I do have lights, and air brake "beep" but nothing happens when turning the key to start. The truck is a fire truck on which I removed the battery switch inside. If there is any one could help , thanks.
Andy
Old Feb 25, 2021 | 08:41 AM
dlburch's Avatar
dlburch
I would take an ohm meter and check resistance from the solenoid mounting bracket to the negative battery cable or a good, clean spot on the frame...it looks suspect to me...and the bracket has to be grounded for the solenoid to work....and make sure that is the correct ford style solenoid with the S and I terminals...
Old Feb 25, 2021 | 09:49 AM
440 sixpack's Avatar
440 sixpack
Jump the solenoid and see if it cranks. this will tell you where to look.
Be sure it's out of gear of course.
Old Feb 25, 2021 | 10:49 AM
Andy Martin
Awesome thank you I'll let you guys know once the weekend shows up
Old Feb 26, 2021 | 08:43 PM
85e150's Avatar
85e150
Bump to the top for moved thread.
Old Mar 2, 2021 | 12:31 AM
Louisville Joe's Avatar
Louisville Joe
Is the cable from the solenoid to the starter grounded? Looks like it might be.
Old Mar 26, 2021 | 11:36 AM
Andy Martin
Will have to double check. I just get a click from the starter and no movement . Seems the engine is locked. So far all the pulleys are good, I'm waiting for a new Starter Solenoid . KNOCK on wood.
Old Mar 26, 2021 | 11:40 AM
Andy Martin
Going to to check my grounds and buy a new solenoid, I just get a click , I got power to ignition coil, also have a trigger tool, but no luck. I tried to put power directly to the starter but it just clicks. BTW its brand new coil;starter and starter/ground wires. MMMM
Old Mar 26, 2021 | 12:13 PM
yardbird's Avatar
yardbird
Pull the spark plugs, put a socket and breaker bar on the crank bolt, and see if the engine will turn over. If it turns over, make a complete revolution and check for any fluids coming out of any cylinders. If so, that would indicate hydraulic lock is your current problem.
If the engine will bar over, then try the starter.
Old Jun 28, 2021 | 06:52 AM
Andy Martin
Thumbs up
So the engine turns now, ATF/Acetone trick. New starter ,plugs & wires as well as a coil but no spark. Next step is ignition module. Any thoughts. Thanks again , Andy
Old Jun 28, 2021 | 04:14 PM
Andy Martin
I pull ignition control module and got the part numbers off to the locate NAPA, also going for a new pickup coil too.
Old Jun 28, 2021 | 04:18 PM
Andy Martin
More pictures.
Old Jul 7, 2021 | 09:58 AM
Andy Martin
Any ideas? After new module and cap/wires, no spark, maybe a bad resistor wire?
Old Jul 7, 2021 | 05:05 PM
85e150's Avatar
85e150
Are you testing components and connections with a meter?
Old Dec 8, 2021 | 09:50 AM
Andy Martin
Question
Hey everybody, So I have no spark, I was told there was ballast resistor that possibly overheated. I posted some photos. Any ideas what is happened with all this old wiring. By the wire it was a old fire truck. Thank again
ballast
link
