97 7.3
Old Feb 24, 2021 | 04:50 PM
Ktleop1959's Avatar
Ktleop1959
There are 2 wires that run to the turbo on my truck I think I'm having turbo issues, with the 2 wire plug disconnected neither one has juice with the key on I checked all fuses I don't have any blown. Does anyone know the correct way to diagnosis this issue? Does the truck need to be running to have juice to one of them, do they not have voltage at all?
Any help would be appreciated.
Old Feb 24, 2021 | 07:59 PM
97-psd's Avatar
97-psd
You are probably looking at the wiring for the exhaust back pressure valve. Lost folks just unplug it. What type of trouble are you having?
Old Feb 26, 2021 | 10:51 PM
Landscape Doctor's Avatar
Landscape Doctor
What are the symptoms that you think you have turbo issues?
Possible issues,,,,
Those 2 wires go to the EBPV (exhaust back pressure valve). Not needed, most delete it. Might be stuck closed. There is a rod that comes out of the actuator at the pedestal, see if you can move it to see if the flap if freely moving, you could also disconnect the down pipe and see if the flap is open or closed. Remove the intake boot and check your turbo wheel to see if it is sloppy or not.
Sticks762
Sep 10, 2019 09:31 AM
Asytole61
13
Dec 3, 2014 12:04 AM
97powerstroke350
Jun 28, 2010 03:34 PM
diesel-fitter-bum01
May 8, 2010 01:13 AM
kpeterson93
Nov 15, 2007 07:47 PM
