2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
tire size
Old Feb 23, 2021 | 01:40 PM
dj867's Avatar
dj867
tire size
hello,
relatively new to the truck community. purchasing a 21 f150 xlt. My package comes with the 18" tires. my question to you all -should i upgrade to the 20" tires ?What are the main plus and minus with different sized tires. I don't tow , and my off roading is exclusively limited to the beach. Thank you .
Old Feb 24, 2021 | 09:35 AM
nitebreeze's Avatar
nitebreeze
For your use, the difference between 18” & 20” relates to sidewall width; the same overall tire size on 18” rim has more sidewall and 20” has less sidewall. Less sidewall means slightly firmer ride but better at speed cornering because less sidewall flex. For overall road ride comfort 18” is better. The other issue is really your appearance preference.
Old Feb 24, 2021 | 09:39 AM
nitebreeze's Avatar
nitebreeze
I don’t drive on beaches but I am guessing you may want to air down your tire pressure on the beach and if so the smaller 18” rim is a better setup for airing down with less risk of losing tire bead seal.
Old Feb 24, 2021 | 11:52 AM
dj867's Avatar
dj867
thank you !
dj867's Avatar
dj867
thank you !
Old Feb 25, 2021 | 10:35 AM
CR172's Avatar
CR172
Please explain your logic on this.
Old Feb 25, 2021 | 04:15 PM
nitebreeze's Avatar
nitebreeze
I drive unimproved dirt roads, jeep roads, truck trails, etc, so I don't air tires down and I am only relaying what I have read. The heavy off road and rock crawling community seems to pretty consistently say the smaller diameter rims are better for airing down and can go to lower pressure without bead failure. It seems that this goes back to smaller rims having more sidewall to flex. A larger rim on the same size tire just doesn't have a lot of rubber to bulge and flex. The recommended rule seems to be a rim diameter half the size of the wheel diameter, so a 35" tires is best on a 17" rim and a 33" tire is best on a 15" rim.
Old Feb 27, 2021 | 08:48 AM
66F100Again's Avatar
66F100Again
I believe Raptors come with 18" wheels too...for offroad consideration.
Old Feb 27, 2021 | 10:22 AM
JKBrad's Avatar
JKBrad
More sidewall to flex means less of a chance of loosing the bead seal with low pressure in the tires. BTW 20" is not an upgrade nor is 18" a downgrade. More about looks than anything. The 18" will ride better and new tires are less expensive. the 20" has a different offset and width which gives a slightly more aggressive stance. 20" factory wheels have 33" tires and the 18s have 32" tires.
SatinBlack03
Modular V10 (6.8l)
Aug 11, 2018 03:15 PM
F250_
19
May 30, 2014 02:38 PM
calexan
2004 - 2008 F150
Aug 5, 2009 07:01 PM
Bammo Fakkie
Aug 11, 2005 05:56 PM
HankB
2004 - 2008 F150
Feb 17, 2004 07:39 PM
