226 trouble shooting help
Old Feb 21, 2021 | 07:04 PM
Myers B's Avatar
Myers B
I am just about finished with my restoration, and the engine has suddenly developed an issue. I have less than five miles on the truck. Engine rebuild within the past 9 months. I am not the best when it comes to trouble shooting, so I'd appreciate anyone weighing in to make sure I'm going in the right direction.
226 6 cylinder, completely stock. Fresh rebuild that included everything.
NEW
Pistons/pins/rings
Pin bushings
Rod/main bearings
cam bearings
valve springs
valves
valve retainers
valve guides
camshaft timing gear
REFURBISHED/MACHINED
camshaft
crank
connecting rods
tappets
valve seats
head leveled
block decked
Lucas 30w break-in oil, oil pressure has been fine.
If I've forgotten to mention anything else that might be relevant, please just let me know.
ISSUE
The engine has previously been running fine without any issues. Here is a video from right after I got it running in the summer.
About two months ago I started the engine up and about 20 seconds after starting it began to make a tapping noise. The tap would go away if you increased RPM, but would come back as soon as it got close to idle. I was working on other projects so I just didn't run the engine much other than to move the truck in and out of the garage, occasionally driving around the block. The symptoms stayed pretty much the same, although once or twice it never made any tapping.
Now that the other projects are done, I decided to dive into the issue today. I started the truck and after 15 seconds or so the tap started just like before. I drove around the block once and it acted the same way as before. I then went a little further down the road and the tapping got a little louder, and it was staying through the higher RPMs. It seemed to be robbing power and affecting the smoothness of the engine. I made a few recordings when I got home. The tap is a little sporadic but it stays mostly consistent. The tap is also in unison with the puffs recorded at the tail pipe. I held my hand against the tail pipe so that you could hear the exhaust easier. Sometimes the tap will go away for a few seconds, but it always returns at some point.
My initial fear was that I was hearing a rod or wrist pin knock. However, removing the spark plug wire from the cylinders one at a time has no effect on the sound. The fact that the engine is running a little rough, and that the tapping matches the odd exhaust puffs makes me think that it is a valve issue. The noise seems to be coming from around cyl 4-6, but it is hard to tell.
The next step that I'm planning on doing is a compression test and then removing the valve covers. Before I go tearing into anything, does anyone have any ideas? Does it seem like the right direction? Thanks!
Video from when the noise first started in December
https://www.dropbox.com/s/qquetm4w0a..._4054.MOV?dl=0
Videos from tonight
https://www.dropbox.com/s/k5m7gs2088..._4426.MOV?dl=0
https://www.dropbox.com/s/oksp1ru16w..._4427.MOV?dl=0
Old Feb 21, 2021 | 07:09 PM
Myers B's Avatar
Myers B
While typing that out I remembered the “paper test”.
I just went out and tested it and the exhaust grabs the paper back and forth at the tail pipe, so I’m fairly confident that I have a stuck valve. I think I'll hook up a vacuum gauge tomorrow just to confirm. The amount of clicking/tapping noise still has me worried.
Old Feb 21, 2021 | 07:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Try drizzling some MMO or Seafoam down the carb while running at ~1500 RPM (don't overdo it, the stuff smokes like crazy!)
I think you're likely right, a sticking valve.
Old Feb 27, 2021 | 03:04 PM
38 coupe's Avatar
38 coupe
Ross had it right, sticking valve. I have heard many reports of modern gas getting old and causing sticking valves.
Any updates?
Old Feb 28, 2021 | 10:20 AM
raytasch's Avatar
raytasch
Believe Nothing
Sticking valve or worse yet, a loose valve seat.
Old Mar 2, 2021 | 06:08 PM
bhalemail's Avatar
bhalemail
Any word on what the issue is/was? I have one that i rebuilt and i'm curious as to what you discover. Please update when you find out
Old Mar 3, 2021 | 07:07 PM
Myers B's Avatar
Myers B
I was able to confirm the diagnosis the day after I posted the question. I wanted to wait until it was all back together before I said it was completely solved though.
No 6 exhaust valve was seized as I suspected. I pulled the head and spent an hour working the valve out of the guide. It was the first time I’ve been completely inside the the engine bay straddling the engine, and hopefully my last.
After getting the valve out, I discovered the reason for the sticking. The assembly lube had dried out and turned to a hard resin. Even though I only had an issue on No 6 so far as I knew, I decided to pull all the valves and inspect. It was a little annoying to pull the manifolds, but I’m glad I did. Three other valves were starting to stick, 2 exhaust and 1 intake.
I cleaned all the valves and guides thoroughly and reassembled using only motor oil. I’ve never had an issue with the Sta-Lube Engine Assembly Lube on any other flatheads that I’ve built. However, I will stick to using oil on the valve stems from now on. Even though it says it’s good for valve stems, I definitely think oil is the only choice.
All in all, it cost about $150 in gaskets and one exhaust valve. It’s frustrating that it was something that shouldn’t have been an issue to begin with, but it’s also good that it wasn’t anything “mechanically” wrong. The truck is back together and running as smoothly as ever. All’s well that ends well I suppose.
Old Mar 3, 2021 | 07:25 PM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
That engine looks good, also like the battery style with logo on it.
Thanks for sharing the diagnosis.
Tom
Old Mar 3, 2021 | 11:27 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
I don't care how careful you are, there's always something that gets you. Glad you got it fixed and it wasn't worse. Now what are you going to do with all your free time? What's next?
Old Mar 4, 2021 | 09:46 PM
38 coupe's Avatar
38 coupe
Glad to hear you got it back to running nicely.
Old Mar 4, 2021 | 10:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Which Sta-Lube Engine Assembly Lube did you use? (they make several) I've never heard of such a thing. Glad you got it fixed! I know all too well the pain of working over those big fenders...
Old Mar 5, 2021 | 12:28 PM
3twinridges's Avatar
3twinridges
LOL...I like how Ross really gets “into” his work.
I felt like this, this week changing a fuel line.
JB
Old Mar 5, 2021 | 04:26 PM
abe's Avatar
abe
Several years ago my BIL helped me put on heads I bought from Dennis, Pinto Plumber. The heads are heavy as you know. And the 53-56 trucks have the fender support rods making it very difficult to put the head in place. My BIL who is short, sat in the engine bay. I handed the head to him and he put it in place.
Old Mar 5, 2021 | 06:33 PM
Bob Ingram's Avatar
Bob Ingram
LOL...I musta looked like that the other day when I was replacing wires on the beam switch, and I’m 6’5” tall.
Quick Cal
1997 - 2003 F150
Dec 3, 2019 07:22 PM
04eddiebauer
Sep 9, 2016 08:42 PM
59Terry
Sep 16, 2015 08:00 PM
Hotairjunkie
Modular V10 (6.8l)
Jun 2, 2012 03:44 AM
seth_stump
Mar 3, 2007 10:55 PM
