2002 E350 SD, No Power, Rough Idle, No Codes
Old Feb 21, 2021 | 06:10 PM
Foxrcng708's Avatar
Foxrcng708
Whats up guys. I have a 2002 E350 Super Duty 5.4. When I first got her she ran but not great. I changed all the plugs and coil packs and she was running great. I was driving home from work one day and pulled up to a light and the engine started vibrating really bad and I had no power. I made it home and looked it over and everything seemed normal. I changed the fuel filter and checked and cleaned all the injectors. Still running like crap. It will not go over 50mph. There are no codes either. Any suggestions would be greatly appreciated.
Old Feb 21, 2021 | 09:51 PM
NICKSAN's Avatar
NICKSAN
Having no codes is a pain. I would first start by looking for a vacumn leak. Are you using an OBD2 scan tool?
Old Feb 23, 2021 | 01:06 PM
Foxrcng708's Avatar
Foxrcng708
yes, I'm using a scan tool. It's very very frustrating. Because it was running perfect then just poof, at a light, rough idle, no power. I'm at a loss
Old Feb 23, 2021 | 01:25 PM
N147JK's Avatar
N147JK
It sounds electrical in nature. Perhaps related to your changing the plugs and coils. I know you don't want to go backward, but you could try changing the plugs and coils back to the originals, one at a time. Along the way, you might uncover the culprit.
Old Feb 23, 2021 | 02:07 PM
Foxrcng708's Avatar
Foxrcng708
I may have found the issue
Old Feb 23, 2021 | 07:49 PM
NICKSAN's Avatar
NICKSAN
Ouch, I hope that didnt do any damage. Were you able check all the plugs?
Old Feb 23, 2021 | 08:13 PM
N147JK's Avatar
N147JK
I don't understand what we're seeing there - has an insert come out along with the plug?
Old Feb 23, 2021 | 08:58 PM
NICKSAN's Avatar
NICKSAN
Me either, it does look like a strange plug. I was referring to the part of the electrode that may be missing.
Old Feb 24, 2021 | 08:10 AM
Foxrcng708's Avatar
Foxrcng708
The tip and electrode is completely gone. And yes, pulled the helicoil out too, but that's no biggie. Unfortunately, I pulled all the plugs and put all new ones in again, still runs like **** with no power.
Old Feb 26, 2021 | 09:34 AM
ceetwarrior's Avatar
ceetwarrior
The coils or boots are probably bad.
Old Feb 26, 2021 | 12:26 PM
Foxrcng708's Avatar
Foxrcng708
Boots and coils are all brand new. Just pulled the plug again and #6 cylinder spark plug has oil on the tip. Not the top or the boot, just the electrode. I'm assuming valves? Or rings? I can't do a compression check because it has helicoils and I can't screw my tester in. I fear the motor will need to be torn apart. Might as well do the timimg chain. I don't know what else to do, I have checked everything.
monte58
Jul 29, 2016 06:45 PM
gassplant
2004 - 2008 F150
Jan 25, 2014 01:01 PM
Cwboy
Dec 17, 2007 06:21 PM
98ford
1997 - 2003 F150
Aug 13, 2005 02:33 AM
