Simple wheel question
Old Feb 20, 2021 | 10:10 PM
Vezfly's Avatar
Vezfly
I have 2020 F350 SRW CCSB 6.7 platinum, found some 20 inch black wheels removed off a 2021 F250 that I want to buy. Are they same wheel; dimensional and load carrying capacity ?
Old Feb 21, 2021 | 08:57 AM
Back2Gas?'s Avatar
Back2Gas?
They should have markings on the inside to answer all those questions. Compare them both...
Old Feb 21, 2021 | 09:07 AM
mcmurm's Avatar
mcmurm
This is the correct answer, but more than likely they will swap over just fine.
Old Feb 21, 2021 | 09:18 AM
B-ManFX4's Avatar
B-ManFX4
If they are factory wheels they are 8" wide x 20" diameter, 8x170mm bolt pattern, +40 offset, 124.9mm center bore, mounting flange type J.
They have the same load capacity on either truck. In short they will fit your truck just fine.
There isn't a change from 2017 - 2021 with regards to 20" wheels.
Old Feb 21, 2021 | 12:33 PM
BOSS 379's Avatar
BOSS 379
The axle diameter on your 350 may be larger than the 250 those wheels are coming from. Therefore there’s a possibility the center hole won’t be large enough.
Old Feb 21, 2021 | 12:50 PM
Keep Truckin''s Avatar
Keep Truckin'
Good point, the F350 diesels and gas with 4.30 rear will have the larger dana axles which means the rear hub diameter will be larger. That said, there are some F250's with the dana axles....heavy duty trailer/tow package?
Old Feb 21, 2021 | 04:33 PM
Vezfly's Avatar
Vezfly
I’m going to call ford tomorrow and ask what part # fits mine , that should clear it up. Thanks for all the input !!
Old Feb 21, 2021 | 05:15 PM
4wd6.7L's Avatar
4wd6.7L
The front axle on both trucks is the same and there is no issue rotating the wheels front to back, sooooo......there shouldn't be any difference in hub diameter. Where the difference might be is in hub length(shorter on the rear Sterling). Center caps might be different on the 350 to accommodate that.
Old Feb 21, 2021 | 09:07 PM
Vezfly's Avatar
Vezfly
Looking at Fords parts website, both 250 and 350 with a 6.7 4Wd show a wheel part # of 1007
Old Feb 21, 2021 | 09:20 PM
4wd6.7L's Avatar
4wd6.7L
Yes, the wheel should be the same. If you can, see if they show a different center cap. From what I recall the hub on the Dana axle protrudes farther out than the Sterling rear does, but maybe all center caps can accommodate either rear axle.
Old Feb 21, 2021 | 09:43 PM
Vezfly's Avatar
Vezfly
thanks- hope to get over there in next few days
Old Feb 21, 2021 | 09:57 PM
Joe T's Avatar
Joe T
If the center caps are the longer ones like yours they will work.
Old Feb 22, 2021 | 07:49 AM
Pugga's Avatar
Pugga
If you're only doing a wheel swap, it sounds like you've found your answer. If you're swapping a wheel/tire combo, check the load index on the tire. I swapped my F250 wheels for a set of black sport wheels/tires from a F350. Both sets of tires were load range E however, my OE tires on the 250 were 123 and the tires from the 350 were 126. Just something to keep an eye on.
Old Feb 22, 2021 | 10:01 AM
4wd6.7L's Avatar
4wd6.7L
Not necessarily a 250/350 thing. Were they both the same Michelin A/T 20" tires? If not it could be an A/S vs A/T thing.
The original 20" Michelin A/T tires on my F250(no extra load packages) are no different than those that come on an F350.
SDTruckMan
Jul 7, 2018 07:29 AM
smlford
Jun 11, 2016 06:25 AM
