Sponsored by: Real Truck
Snow chains fitment
Old Feb 17, 2021 | 06:15 PM
12F350's Avatar
12F350
Snow chains fitment
12 F350 SRW 4x4,
I have 275/65/20 tires on truck.
will snow chains for 275/60/20 fit in a pinch?
(have a pair from an older truck)
Also I’m getting mixed info on google.
snow chains on front or rear tires of a 4x4? ( only one set)
thanks
Old Feb 18, 2021 | 05:46 AM
Desert Don's Avatar
Desert Don
Originally Posted by 12F350
12 F350 SRW 4x4,
thanks
Try them and see. Then YOU know. Also, if they come up a link or two short, they are easy to lengthen with a couple of quick links.
Carry a few with you for quick repairs anyway.
Old Feb 18, 2021 | 01:50 PM
EDC8008's Avatar
EDC8008
The 260s should fit, maybe a little tight.
Old Feb 18, 2021 | 07:17 PM
destroy's Avatar
destroy
Depends on the chains themselves. There’s many different kinds, and most kinds (unless custom made/fit) have a number of different sizes that they say they’ll fit.
Those two tires are so close chances are you’ll find one that does, but check when you buy, unless you already have them and can’t figure out what you have.
I have a set of those gnarly welded v-bar chains for when it gets really dicey up here in the Columbias. Worth having.
Old Feb 19, 2021 | 12:37 AM
EDC8008's Avatar
EDC8008
Typically you need to put them on the drive axle which is the rear. If you have 2 sets and a 4 wheel drive then you can put them on both front and rears.
I typically will only carry mine in cases where the chain laws are in affect. I have 2 sets for my truck, one set of plain chains and one set of the reinforced, in those cases when the law is in affect as they will turn you around in the northwest. The reinforced go in the back and the plain chains go in the front, 30 mph max speed.
When it gets bad I put about 500lbs of weight in the back of the truck and pretty much go where ever I need to go. I have a 75 gallon transfer tank so by filling it up I get about 600 lbs of ballast and when the weather clears i just put it in the truck. Big key is weight over the rear axle as it is supper light.
winginit
Transit Connect
Feb 17, 2021 10:41 AM
AZC
Jan 28, 2021 09:25 AM
afinepoint
Jan 27, 2004 04:42 PM
wolffpax
Bronco II
Sep 13, 2003 11:14 AM
