Heater issue
Old Feb 17, 2021 | 06:07 PM
Clay Rogers's Avatar
Clay Rogers
Heater issue
Hey guys, I have a 2004 Ford Excursion 6.0. I have no heat or defrost at idle, but quickly heats up once moving. I have replaced the vacuum pump. No head gasket issues, as they checked that, new radiator, new degas bottle, and heater core flushed. Any ideas would be greatly appreciated
Old Feb 17, 2021 | 07:07 PM
Dweber85rc's Avatar
Dweber85rc
What is your actual engine temperature compared to what the gauge shows?
Old Feb 17, 2021 | 07:37 PM
Clay Rogers
About 150-160 at idle.
Old Feb 17, 2021 | 08:59 PM
Dweber85rc's Avatar
Dweber85rc
I have no direct experience with the 6.0 but to me it Sounds like your thermostat is stuck open.
Old Feb 17, 2021 | 09:04 PM
Clay Rogers
I forgot, replaced that too.
Old Feb 18, 2021 | 05:39 AM
DinoB's Avatar
DinoB
I have the exact same issue with a 2003 6.0. Around 1200 RPM it will blow nice warm/hot air. At idle cold. I have changed heater cores, thermostat, etc. no head gasket issues either. I was told to add more coolant..... that didn’t work. I would love to figure this out also.
Old Feb 18, 2021 | 10:45 AM
DinoB's Avatar
DinoB
DWeber..... if Clays issue is the same as mine then the thermostat is not the problem. If tstat fails it will fail open or at least partially open. This will cause the ECT and EOT not to get to operating temp. Our issu is that the temps will come up to where they should be but we will not get heat at idle/ low rpm. In my case around 1200 rpm and it blows as hot as you want to make it. Let off the throttle and it will blow cold .
Old Feb 18, 2021 | 01:53 PM
DinoB's Avatar
DinoB
Clay.... have you looked into the heater core valve? I just ordered one for mine. Had a few people suggest it on another forum. You can google it Ford pn# YG-389.
Old Feb 18, 2021 | 04:09 PM
01__Excursion's Avatar
01__Excursion
Worn water pump impellers?
Old Feb 18, 2021 | 04:51 PM
DinoB's Avatar
DinoB
I hope not..... brand new BPD billet water pump.
Old Feb 19, 2021 | 06:45 AM
Dweber85rc's Avatar
Dweber85rc
Are both hoses of the heater core hot? What about the rear heater, is it hot? I am going through this with mine right now, but mine is a v10. It is getting to operating temp at idle however the heater puts out better heat at higher rpm. I am suspecting a partially plugged core on mine.
Old Feb 19, 2021 | 06:56 AM
DinoB's Avatar
DinoB
Both hoses hot. Both heater cores have been replaced. Have u recently flushed your coolant system?
DinoB's Avatar
DinoB
Forgot ..... rear heat is fine.... same as front.
Old Feb 19, 2021 | 02:58 PM
ToolmakerRob's Avatar
ToolmakerRob
Could you check to make sure that the temperature adjustment door is actually moving to full "hot". It is a good sign that both heater hoses are hot.
What was the actual test someone did to say the HGs were Ok? Just inquiring as when my HGs went it did the same thing and I am not trying to scare you.
What make was the thermostat? Do you have a full engine monitoring system on?
The waterpumps on a 6.0 are marginal at best for flow at idle.
Rob
Old Feb 19, 2021 | 03:47 PM
DinoB's Avatar
DinoB
Rob,
for HGs.... bubble test, degas bottle pressure test, homemade HERO kit, test for exhaust gases in degas bottle. I do have full monitoring via CTS2. ECT/EOT with max spread of 9 degrees. No rough idle, white smoke, poor performance. T stat is FoMoCo. I have no issues with temperatures as long as rpm is about 1200 or over. No puking from degas bottle. I do not have an EGR. Coolant filter, oil cooler relocation kit. Runs great with zero issues other than it won’t blow warm air at idle. Coolant level hasn’t changed.... I keep it just below cold line on bottle. Have a new degas cap. Both heater cores are new. I also have the billet BPD water pump that is less than 2 years old. This thing is driving me 😜
