Burning Smell
Old Feb 16, 2021 | 11:04 PM
killjoykarl's Avatar
killjoykarl
Burning Smell
When i put my 2018 xlt 6.2 in 4wd i get a burning smell through the heater. Any tips would be helpful Thank you
Old Feb 17, 2021 | 05:25 AM
Germanrazor's Avatar
Germanrazor
Hmmmmm? Waiting to see what this may be.
Old Feb 17, 2021 | 06:18 AM
Pugga's Avatar
Pugga
Check your cabin air filter, make sure you don't have a nest or a bunch of leaves in there.
Old Feb 17, 2021 | 10:50 AM
NorEasterMA's Avatar
NorEasterMA
I dunno, I've had a smell like that in 4hi and when plowing since truck was new. I know many folks have experienced the same smell. No idea what the root of this is, but after 60K it's not been an issue for anyone including myself. Run with it!
Old Feb 17, 2021 | 04:20 PM
jjbbrewer's Avatar
jjbbrewer
Was it in the middle of a regen cycle when you stopped?
Old Feb 17, 2021 | 05:53 PM
GRWolverineFan's Avatar
GRWolverineFan
It’s a 6.2 so I doubt it.
Old Feb 17, 2021 | 07:35 PM
Crotchety Ford truck only's Avatar
So you think the smell might be coming through the engine bay and going into the cowl vent at the windshield ? If that were my truck I'd worry about it. That truck would be on 4 jack stands with cribbing maybe for safety and I'd be running the drive train looking, checking, touching and maybe pull out my infrared thermometer. I would find what it was in about a half an hour, that would be the easy part. Don't forget to have the person running it step on the brakes before they put it in park (doesn't sound good).
That's a nice handle Karl.
Old Feb 17, 2021 | 08:38 PM
Barbero's Avatar
Barbero
On a F150 4x4, I kept smelling a faint propane/sulphur/rotten egg odor when the air vents were open, or when standing near the front wheels when parked with hot engine. Turned out the front drive shaft CV seal had a small leak that sprayed CV lubricant onto an exhaust component. Only fix was to replace the drive shaft, and clean as much of the glazed residue off the exhaust as possible (tight spaces). That fixed the problem. No odor since.
Old Feb 17, 2021 | 09:30 PM
Mack3006's Avatar
Mack3006
My 17 6.2 f250 (38k miles)smells like burning when I’m in 4wheel. Just noticed it this winter.
not really while on the highway. But definitely when parked
Old Feb 17, 2021 | 10:06 PM
So that must mean it is a slight smell (small something overheat).
Old Feb 17, 2021 | 11:18 PM
mhoefer's Avatar
mhoefer
Brand new truck, lots of labels, stickers and stuff all over the place. Probably something on exhaust or other hot component somewhere off gassing.
Old Feb 18, 2021 | 07:22 AM
jjbbrewer's Avatar
jjbbrewer
GRWolverineFan
Ha! I misread that. Sorry.
Old Feb 18, 2021 | 10:03 AM
killjoykarl
It’s actually my power steering is leaking on to the front diff. I thought it was just hard to steer because of all the hard back snow. No it’s just a failed power steering unit. Anyone know if this is easy to replace or should I have a pro do it.
Old Feb 18, 2021 | 11:04 AM
Thanks for the update. If it were mine and out of warranty I would still take it to dealer. I do my own brakes, fluids, front end and some suspension, used to do all my own stuff except rebuild a tranny. These new vehicles w/o a lift and a lot of times specific knowledge is tough.
Old Feb 18, 2021 | 11:15 AM
TCNashville's Avatar
TCNashville
Still under warranty? Have the dealer do it. Of course, if you want it done right.........
