Heat/AC not working
Old Feb 15, 2021 | 09:00 PM
Mikey21's Avatar
Mikey21
Heat/AC not working
My blower motor dosnt even attempt to turn on, I’ve replaced the resistor, and the motor, any advice, also could extremely cold weather affect it in any way
Old Feb 15, 2021 | 09:45 PM
DarkOverCast's Avatar
DarkOverCast
I'm sure you've checked the fuses, but it's possible the wiring melted somewhere out of the connector or made a bad connection or the speed selector switch is bad.
Maybe lonewolf will see this and post a wiring diagram for you and maybe you can find out where the power is vanishing.
I recommend to clip the power wire at the blower motor, add in a relay with a 30 amp fuse off the battery, and use the original power wire to trip said relay. Ground must stay oem because that's the side that does the speed switching.
Old Feb 15, 2021 | 10:49 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I assume this is for 1990......
Hesson81
Aug 26, 2020 04:59 AM
Seth Kell
Mar 7, 2020 06:53 AM
thor363
Aug 29, 2019 07:49 AM
Skyline Drive
Jan 30, 2015 06:50 PM
f100guy
Dec 5, 2003 12:25 AM
