Leave side steps down?
Old Feb 15, 2021 | 10:47 AM
Squirrel13's Avatar
Squirrel13
With all the snow the steps have a nasty amount of crud up against the body. Id like to go thru the carwash with steps down. Is there a away to have them down without a door open?
Old Feb 15, 2021 | 11:35 AM
4wd6.7L's Avatar
4wd6.7L
Yes, it is the dash menu. I'm not in my truck at the moment to give a step by step. They will retract at something like 3 mph though. No way to override that.
Old Feb 15, 2021 | 11:38 AM
4wd6.7L's Avatar
4wd6.7L
Here you go....
Old Feb 15, 2021 | 12:31 PM
Squirrel13's Avatar
Squirrel13
Originally Posted by 4wd6.7L
Here you go....
Thank You so much
Old Feb 15, 2021 | 02:10 PM
nuctrooper's Avatar
nuctrooper
Secondary option is to just step on it immediately after you close the door. It’ll sense an obstruction then stay down. I do that on occasion in parking lots if it is a little tight. If another car door dings you, it is on the step and not the door panel.
Tougher to use that at an automated car wash when you’re inside the truck-need to do the dash selection then.
Old Feb 15, 2021 | 02:46 PM
Crotchety Ford truck only's Avatar
No way to over ride in the truck menu....... certainly able to over ride other ways.
Old Feb 15, 2021 | 04:24 PM
Squirrel13's Avatar
Squirrel13
Worked like a charm. As i pulled in I set steps to out. Cleaned them right up. Thanks guys
Ryan Kovacs
Jan 19, 2017 08:19 PM
TRX250R87
2004 - 2008 F150
Feb 26, 2008 09:09 PM
Slow
Dec 5, 2005 03:51 PM
MMills06
New Hampshire Chapter
Jan 27, 2005 11:57 AM
yenima38
Mar 13, 2002 01:59 PM
