Sponsored by: Real Truck
Track Bar position
Old Feb 15, 2021 | 02:48 AM
reconstyle's Avatar
reconstyle
Track Bar position
I just installed a PMF adjustable track bar and a new XRF ball joint. I measured the stock track bar and set the PMF track bar to the same length. After the install, I made sure the front axle is centered under the truck, but the ball joint stud is angled towards the drivers side a little bit - is this normal? I would think when setup correctly, the ball joint stud should be pretty much perfectly vertical (perpendicular to the ground) but I don't remember what the factory setup looked like when I pulled it off. Truck is stock height.
lukemiller
6.4L Power Stroke Diesel
Mar 4, 2020 12:52 PM
GOT2BA1
Jun 26, 2017 02:35 PM
simsbud
Jun 25, 2012 12:05 AM
