fuel sending unit
Old Feb 11, 2021 | 03:23 PM
jrpitdog's Avatar
jrpitdog
fuel sending unit
I have an 89 250 with the double tanks. Are the fuel sending units the same for both tanks?
Old Feb 11, 2021 | 03:28 PM
subford's Avatar
subford
Deleted, Deleted.
Last edited by subford; Feb 11, 2021 at 06:36 PM. Reason: Info was for newer type truck.
Old Feb 11, 2021 | 03:30 PM
timepiece's Avatar
timepiece
I have a 1988 250 and if I remember correctly from when I changed mine that they are shaped differently on account of the different shape of the two tanks.
Old Feb 11, 2021 | 04:19 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
If you are asking about the in tank pump/gauge sender assembly, they are different.
Old Feb 11, 2021 | 04:42 PM
jrpitdog's Avatar
jrpitdog
I am asking about the gauge sending unit....so they are different or the same? lol getting different answers
Old Feb 11, 2021 | 04:50 PM
jrpitdog's Avatar
jrpitdog
Ok, so I looked up part numbers on rockauto, looks like they are different.
One other question...I know that each sending unit has a small pump, Im assuming there is another hp fuel pump as well further down the line? There is just one of those, correct?
Old Feb 11, 2021 | 06:17 PM
josiewales's Avatar
josiewales
On that model truck with two fuel tanks, each tank has it's own pump and gauge sending unit. The switch on the dashboard controls which pump runs. The fuel then goes to a "reservoir" unit on the frame under the drivers seat. That unit then switches to send the surplus fuel back to the tank that pumped it - or at least it's supposed to. What happens in reality, it doesn't always switch, so the surplus fuel goes back to the other tank, filling the wrong tank. From the reservoir, the fuel then goes to a frame-mounted higher-pressure pump and then thru the fuel filter, then to the engine - all of this on the frame under the drivers seat.
The switch on the dash doesn't control the reservoir valve, it controls which pump puts pressure into the reservoir valve, that pressure is supposed to control the valve.
scottlathrop
Sep 28, 2016 06:33 AM
valpro99
Jun 7, 2013 11:52 PM
tibbytom
May 18, 2013 05:47 AM
jeem
Jan 11, 2006 09:48 PM
Manwith3fords
Sep 30, 2003 02:12 AM
