1990 ford aerostar
Old Oct 26, 2003 | 03:31 PM
cableguy815's Avatar
cableguy815
1990 ford aerostar
after i replaced the timing chain gasket on my 1990 aerostar it cuts out between 45 mph and 50 mph. any speed below or above that is fine. any ideas on what might be causing this?
Old Oct 26, 2003 | 04:39 PM
95BlackF150's Avatar
95BlackF150
does it have crank sensor ?
Old Oct 28, 2003 | 03:22 PM
cableguy815
Not real sure but I believe it does. Don't get to look at it much because my wife has it alot. I can understand where that might have something to do with it. I thought mady it was a fuel injection problem but it don't add up. Has got to be something with the timing i'm thinking or as you said maby the crank position sensor.
Old Oct 28, 2003 | 03:38 PM
95BlackF150
they can be fragile at time could have cracked it had to replace on in my wifes car cept it was called cam sensor buy some parts stores
