P430 ford f 150 code
Old Feb 6, 2021 | 07:43 PM
Peter Regalado's Avatar
Peter Regalado
I have a ford f150 2005 and check engine light came out so I put the scaner it came this code P430 catalyst system efficiency below there should bank 2 I just buy this truck and I went to a place to get it fix they came with this price $1,234 I don't have work cuz the virus im checking online for options this one they say just cleaning the catalyst using foam clear and show the work but Iim don't I need help how to fix this for the best peter peds5450@outlook.com
Old Feb 7, 2021 | 05:48 PM
senix's Avatar
senix
moved to the F150 forum for your year.
Old Feb 8, 2021 | 07:53 AM
F150Torqued's Avatar
F150Torqued
@Peter Regalado , You need to have someone with a good scanner check the OBDII parameter called "MILES DRIVEN SINCE CODES CLEARED", and "P1000", and "EMISSIONS TESTS COMPLETE" "TRIP CNT", etc etc. If it indicates the person who sold you the vehicle had just cleared the codes, you oughta' sue the hell out of them! There are numerous parameters in OBDII that will support / confirm whether the dealer was trying to screw you by hiding something. Numerous codes (such as CAT codes and CAM codes) require multiple drive cycles to pop up. Some car salesmen have code readers and routinely reset codes.
Having said all that, your P0430 doesn't _necessarily_ mean your CAT is toast. You could have something else (vacuum leak on bank 2, misfires -flashing CEL, overactive injector) or something else overwhelming the CAT causing it to operate below factory spec efficiency. If that is the case, correct that QUICK - before ruining the CAT, and it could be fine.
Last edited by F150Torqued; Feb 8, 2021 at 07:57 AM. Reason: Added TAG since post moved to different Forum
Old Feb 10, 2021 | 07:02 PM
WWR's Avatar
WWR
Torqued's gonna yell at me but anti-foulers work wonders. Seriously. Torqued'll say I'm a hack but that's what I'd do...no emissions inspections for me and I refuse to spend more $$ than necessary to make the gubermint happy. I know, I know I'm a horrible person and I'm killing us all. Look over there! C19! Focus on that fear for now...
Old Feb 15, 2021 | 10:48 AM
F150Torqued
Naah -- you're cool. Just that My only experience with P0420 / 430 code was curred when I got rid of the misfires, and they 'healed'. With 260k miles on her now, I'm not so sure I'd be against the hack now if they came back on a perminent basis.
alpha/omega
Offroad & 4x4
Feb 28, 2010 08:15 AM
greatwl
Sep 3, 2004 01:01 PM
Magnum13
Jul 18, 2003 10:40 AM
