Sponsored by: Real Truck
Not a fuse
Old Oct 26, 2003 | 01:59 PM
Rick P.'s Avatar
Rick P.
Not a fuse
I have a 2002 F-250 SD. The problem I have is none of the gauges are working but all the idiot lights are on( door ajar, check gauges,gas light,etc.).My power windows, radio and interoir light are also not working.I checked all the fuses and relays 5 times and they are all fine. Any ideas, can I fix it myself or is it a dealer problem?
Old Oct 26, 2003 | 09:13 PM
99f350sd's Avatar
99f350sd
Did you check fuses under the hood? could be something with the ignition sw
Old Oct 26, 2003 | 11:26 PM
FortyFords's Avatar
FortyFords
You need to chk fuse 35,41 again !
they pwr the instrument cluster.
Within the instrument cluster is 2 relays k115 and k333.
k115 is battery saver ,k333 is interior lamp relay.
Both of the fuses above have 12v all the time .
Chk to see if 12 v is present .
This could be simple or could get very complicated with the need for schematic's .
which is what I'm looking at right now.
If your out of warranty ,you 'll need schematic's .
Rich
