The dreaded rust
Old Feb 11, 2021 | 07:23 AM
machinehead45's Avatar
machinehead45
Yes sir I have a dose of that as well!! So I found a donor vehicle stripped in a pick and pull. They will allow me to cut panels out. So Ive got a source for my dog legs, crossmember, a random section of floor pan and running board supports that I needed could I also use the rockers from the donor or would it be better or easier to buy new?
Old Feb 11, 2021 | 07:30 AM
Dweber85rc's Avatar
Dweber85rc
I guess if it were me I would at a minimum replace the outers. You have to take the outers off to install the inners anyways.
Old Feb 11, 2021 | 07:50 AM
machinehead45
Copy that! New sounds good! Just wanted to see if while I was cutting out panels from the junkyard if I should take them or leave them thanks again I'm looking forward rounding up everything and getting started!
Old Feb 11, 2021 | 12:11 PM
Dweber85rc's Avatar
Dweber85rc
If you can get the inners the nice thing is you can get exactly what you need. The after market exchange inners are really about 8 inches short in the back by the rear wheel if you have really bad rust, like mine did.
Nogoldformarfa
Sep 23, 2018 10:58 AM
center97
2009 - 2014 F150
15
Feb 9, 2015 09:32 AM
EM1/SS(ret)
May 8, 2011 11:29 PM
aerostargal
Aerostar
Jan 27, 2006 02:47 AM
Paddy Whacker
Dec 31, 2005 04:40 PM
