Hesitation
Old Feb 6, 2021 | 08:37 AM
MEVANS52's Avatar
MEVANS52
Hesitation
I have a 2019 F250 6.7 Turbo Boost, I am experiencing at times hesitation when pulling out after setting in traffic or a traffic light.
it is like the engine has no power or is bogged down.
Any thoughts?
Old Feb 6, 2021 | 09:18 AM
The Bone's Avatar
The Bone
Turbo lag. All diesels have it. step on the gas and not much happens then all of a sudden you got power. Turbo Lag.
This is normal.
Old Feb 6, 2021 | 10:35 AM
sPickins's Avatar
sPickins
Banks Pedal Monster... Find my post on that sucker, 100% worth the price of admission.
Old Feb 6, 2021 | 12:05 PM
Overkill2's Avatar
Overkill2
x2. That will be the next thing for my truck but first a AFE DFS780 pump on mine, then install the used Derringer Tuner and 2nd iDash I bought.
But here's a good explanation of what's called the Drive by wire torque management system in the ECM.
From this link:
https://5startuning.com/got-2017-6-7...r-duty-diesel/
Hope this helps.
Old Feb 7, 2021 | 05:34 AM
sPickins's Avatar
sPickins
Originally Posted by Overkill2
Stock tables are conservative and numb
Yep, describes the stock acceleration honestly and accurately...
Old Feb 7, 2021 | 10:34 AM
HRTKD's Avatar
HRTKD
There's a thread out there with a lot of complaints about hesitation. I don't recall if it's limited to the 6.7L or if it's also the gas engines. It's mostly 2020 and 2021 vehicles, so there's speculation that the 10 speed transmission is the culprit. Since the OP of this thread has a 2019 6.7, the 10 speed transmission isn't the issue. It could be turbo lag, but without being there, it's hard to say.
Old Feb 7, 2021 | 02:33 PM
Overkill2's Avatar
Overkill2
We have Ford Explorers at work and it's pretty pronounced when you go to step on it. Not saying it's all vehicles, gas and diesels, but maybe it's a thing with these modern vehicles with computer controlled throttle pedals.
Old Feb 7, 2021 | 05:31 PM
Trang64's Avatar
Trang64
My #1 gripe with Ford's programming, close second is how the damn truck cuts power the split second I need more and am about to get stuck in mud or snow, even with TC off. Way to go Ford engineers! You are #1.
My problem has been with the V10 and the 6.2, definitely not just a diesel issue.
Pro Form
Dec 6, 2010 02:59 PM
fmx_freak
Jul 10, 2010 02:12 PM
cdrmotorsports
Jul 1, 2009 10:56 PM
jackstruck
Nov 11, 2005 01:00 PM
