View Poll Results: Which direction do you like the dual SS mounted?
Piston toward the outside mounts?
76.19%
Piston toward the center mounts?
23.81%
Voters: 21. You may not vote on this poll
Dual S. Stabilizer Visual Question
Old Feb 4, 2021 | 09:05 AM
rprice32's Avatar
rprice32
Got my dual SS ordered. Now, I’m seeing them mounted both ways; piston to the outside and piston to the center mounts. Going to ask which way you like, and why.
Old Feb 4, 2021 | 11:40 AM
JD'sBigredv10's Avatar
JD'sBigredv10
I just installed the PMF kit with Fox stabilizers. The instructions state that they should be mounted with the bodies towards the center.
Old Feb 4, 2021 | 12:12 PM
KeystoneF350's Avatar
KeystoneF350
I have the Kelderman dual stabilizer and the shock bodies are also mounted toward the center. If mounted with the shock body towards the outside, the shock body will contact the mounting brackets on the tie rod ends while turning lock to lock.
Old Feb 4, 2021 | 02:41 PM
rprice32's Avatar
rprice32
Thanks guys. I’ve seen some videos and pics where they were mounted both ways, so I thought it might be personal preference.
Old Feb 4, 2021 | 03:05 PM
Zchludil's Avatar
Zchludil
Can’t remember what kit I went with, but the instructions said to mount the pistons towards the outside.
Old Feb 4, 2021 | 04:07 PM
rprice32's Avatar
rprice32
Got to say... you guys’ trucks look great with those. I’m going to believe the slight slop I’ve feeling in the front, will be history soon.
Old Feb 4, 2021 | 06:06 PM
4wd6.7L's Avatar
4wd6.7L
I need some clarification, is the piston referring to the shock body, or shaft?
Old Feb 4, 2021 | 07:54 PM
Killer-Bimmer's Avatar
Killer-Bimmer
Haha... Glad I'm not the only one, have rebuilt, tuned, broken, repeat many many times and the piston has always been in the body/cylinder... Hence I'm the lone ranger in the poll Now if your talking about the shaft as being the piston because it's attached to the shaft I guess that works to, but all my years in MX, road racing etc... have never seen it posed this way....
Old Feb 5, 2021 | 06:17 AM
rprice32's Avatar
rprice32
Sorry. I’m referencing the shaft as the piston rod. Mix on words. To me, those pics above represent the “piston” to the outside/cylinder to the inside.
Old Feb 5, 2021 | 09:00 AM
speakerfritz's Avatar
speakerfritz
on my 2019 f-450 using PMF and fox, I had less than 1/16 clearance between shock body and one of the cross bars. called PMF and they said it was OK to reverse the install so that the bodies were outboard.
might be a consideration if you have an f-450 to determine which shock body has the smallest diameter so there is more clearance.
Old Feb 5, 2021 | 09:56 AM
Daddy454's Avatar
Daddy454
I can't say I've ever seen them mounted with the shock body to the outside.Not saying you can't,just haven't seen it.That said,my Keldermann mounts shock body to the center......and I think they look better that way as well.
Old Feb 5, 2021 | 11:24 AM
Killer-Bimmer
All good, but technically in the pictures the piston resides in the body, and the rod/shaft is outbound! So with that my single vote would be moved😉
Old Feb 5, 2021 | 12:33 PM
rprice32's Avatar
rprice32
I’ve seen many more mounted with the body toward the center, but when I saw a few mounted the opposite way, it seemed to be more of a personal preference. Here’s a pic of one that had me questioning.
Old Feb 5, 2021 | 05:09 PM
TheProcess's Avatar
TheProcess
I just had my truck done and the shock bodies are mounted toward the outside. This is the kit that BDS sells with their lift kits. In the instructions it specifically says to mount the shock bodies to the outside bracket.
Old Feb 5, 2021 | 05:29 PM
rprice32's Avatar
rprice32
Roll Tide, TheProcess! Looking good!
