1995 302 timing
Old Oct 26, 2003 | 09:29 AM
nooner's Avatar
nooner
1995 302 timing
Set my timing with spout disconnected. When I reconnected spout only saw 3' timing change. Does anyone know how much spout should change timing? Also why it would not.
Old Oct 27, 2003 | 09:38 PM
DW2455's Avatar
DW2455
well its controlled by the ECM, but most important is how does it run? any problems? disconnect the battery for 10-15 mins. to clear the codes, then if it runs ok drive it for a couple of days and see if it stores any new codes and go from there. DW
Old Oct 27, 2003 | 10:27 PM
circledirt's Avatar
circledirt
3 degrees only at idle or also at higher rpm? With spout disconnected timing should stay at base no matter what rpm. Should advance with spout connected and increase with rpm. ECM watches IDM(ignition diagnostic monitor) from ign module. But if ECM doesn,t see this it will set a code.
Old Oct 28, 2003 | 07:52 PM
nooner's Avatar
nooner
Thanks, Timing does advance with rpm. Someone had told me it should jump off scale just reconnecting spout. I thought it should advance with rpm.
