Sponsored by: Real Truck
2005 V10 Kill Switch
Old Jan 29, 2021 | 08:26 AM
uhomebody's Avatar
uhomebody
Unfortunately we are seeing an increase in our area for thefts of Ford trucks. My truck (CC 05 V10) lives outdoors and even though we are in a small, middle class culdesac I am paranoid.
I was thinking of installing a Killswitch. Wanting to install one but wanted to check here see if anyone has done this previously and which wire to tap into specifically. I don’t drive the truck but once a week or so, it is primarily used to tow travel trailer.
Being that I don’t drive it regularly I want to make sure whatever wire I tap into, if I forget to flip that kill switch on when I start it, I don’t break something.Ng7}JtaSBeing that I don’t drive it regularly I want to make sure whatever wire I tap into, if I forget to flip that kill switch on when I start it, I don’t break something.
Thank you!!
Old Jan 29, 2021 | 10:47 AM
projectSHO89's Avatar
projectSHO89
There are numerous places where it could be spliced in- Ignition feed, starter circuit, fuel pump circuit, etc.
You'll just have to "pick your poison", as it were.
Old Jan 29, 2021 | 11:05 AM
obsxl's Avatar
obsxl
if your truck has a fender mounted starter relay/junction post you could wire it between that and the battery
Old Jan 30, 2021 | 10:05 AM
super 6.8's Avatar
super 6.8
I would think tapping into your fuel pump inertia switch wiring would be an easy route. If you left the kill switch near the inertia switch a thief in the driver's seat would never find it.
V8Notch
Modular V10 (6.8l)
21
Sep 26, 2017 08:58 AM
Majic31
Jan 18, 2017 08:37 PM
denk
Jul 15, 2013 10:44 PM
nikwave
May 28, 2009 06:50 AM
weldman
Electrical Systems/Wiring
May 22, 2001 08:23 PM
