1965 VIN Decode
Old Jan 28, 2021 | 09:21 PM
geetoe's Avatar
geetoe
1965 VIN Decode
Hi, can someone decode this VIN? It doesn't jive with what's on the Fordification site. Thanks!
Old Jan 28, 2021 | 10:23 PM
85e150's Avatar
85e150
1966 F600 with a 330 2V medium duty FT engine, the one with the FE crank.
vinwiz.com VIN Decoder
Is it in fact an F600? Your picture looks like a pickup.
If it's a pickup, then that tag came along with a replacement door.
If it's really an F600 cab and chassis, let's move you to Large Truck and a full decode.
Old Jan 29, 2021 | 06:59 AM
geetoe's Avatar
geetoe
Good morning! It is a pickup. And a six cylinder. I wanted to know what size the 6 cylinder is. It's my parts truck. Thank you!
Old Jan 29, 2021 | 02:07 PM
85e150's Avatar
85e150
IF it's a '65, it would be a 240 or 300. Intake and exhaust is on the passenger side on those. The prior generation had the intake and exhaust on the driver side.
As to how to tell if it's a 240 or 300, you can use a piece of wire down a spark plug hole, and rotate the engine. Note how far the wire moves. 3.18" = 240, 3.98" = 300.
Old Jan 29, 2021 | 04:57 PM
SuperSabre's Avatar
SuperSabre
Since it's apparent that the warranty plate attached to your driver's door is not the correct one for your truck, it would possibly be useful to find out what your truck's correct VIN is. Assuming you have a title for it, is there a VIN listed on the title? The VIN is stamped on top of your frame rail on both the driver's side and on the passenger's side. Annoyingly, the one on the passenger side is usually under the cab so can't be seen without removing the cab, but the one on the driver side should be found on the TOP of the rail, and I hope to attach a picture to help you find it. Sometimes the stamping isn't very deep so be very careful with your wire brush, paint stipper, etc.that you don't erase it while you are searching for it. If the VIN is correct, it might start out something like F10YK.... The F10 = F100 half ton two wheel drive pick-up. The next letter = which engine it left the assembly plant with depending on what model year it is (1965: D = 352 c.i. FE V8, 2 bbl. 1966 - 67: Y = 352 c.i. FE V8, 2 bbl. 1966: A = 240 c.i. I-6, 1 bbl. 1966: B = 300 c.i. I-6, 1 bbl. etc.) The next letter = which plant assembled the truck. K = Kansas City. There are about 10 other possibilities. When you find your VIN report what it is and someone will finish decoding it for you. Good luck!
You might just be able to make out the VIN on the closest frame rail.
The VIN will have little stars at the beginning and at the end.
ymountainman
Large Truck
Aug 10, 2020 05:16 PM
Rusty Fords
Jul 16, 2020 06:34 PM
Rusty Fords
Apr 27, 2020 10:47 PM
ymountainman
Large Truck
Apr 14, 2020 12:01 PM
