Edelbrock choke
Old Oct 26, 2003 | 07:35 AM
Finnford's Avatar
Finnford
Edelbrock choke
Purchased a used 1405 Edelbrock with a electric choke on it. The choke has a vacuum port coming out the bottom. Where should it be connected or can I just leave it plugged?
Runs fine plugged. Unplugged the motor idles with a miss.
Have a performer intake with Edelbrock air cleaner, 351 W motor.
Old Oct 26, 2003 | 11:38 AM
LxMan1's Avatar
LxMan1
It's an internal vacuum, leave it plugged.
Jimmy
Old Oct 27, 2003 | 06:06 AM
Finnford's Avatar
Finnford
Thanks for the info. I am one of those people that wants to know why is it there if it is not to be connected. I have looked at other carbs and the port is not there. I was having problems until I replaced the plug, dry rot.
Old Oct 28, 2003 | 09:42 AM
Finnford's Avatar
Finnford
My mistake, by plugging it with a new plug, I developed a problem with it surging and dying at stop lights. Will replace with old cap and see if it goes back to where it was. That port seems to do something, any feed back would be appreciated.
Old Oct 28, 2003 | 11:43 AM
LxMan1's Avatar
LxMan1
I believe that it is supposed to have a solid plug pressed in it. If you plugged it and the idle changed, then I would try readjusting the mixture screws on the front of the carb.
Jimmy
Old Oct 28, 2003 | 01:25 PM
Finnford's Avatar
Finnford
It looks like at rubber tube connector, look at link attached and it is where the 9 arrow is pointing.
Go to the
Exploded View of Edelbrock Performer Series Carburetor
http://www.edelbrock.com/automotive/index.html
Old Oct 28, 2003 | 01:33 PM
LxMan1's Avatar
LxMan1
The choke piston housing?
Old Oct 28, 2003 | 01:46 PM
LxMan1's Avatar
LxMan1
I was going to e-mail you a picture to see if we are talking about the same thing, but you have e-mail turned off. E-mail me and I will reply with a picture of my carb to see if we are looking at the same thing.
Jimmy
Old Oct 28, 2003 | 08:39 PM
LxMan1's Avatar
LxMan1
You've got mail.
SC'79
53
Apr 2, 2013 04:10 PM
hotrod351
Mar 26, 2010 06:26 PM
66f100352
Dec 7, 2009 12:12 AM
COLEnMICHAELS66
Sep 11, 2007 02:45 AM
Bill79Lariat
Dec 31, 2003 08:52 AM
