Maf conversion
Old Jan 28, 2021 | 03:21 AM
Jm24's Avatar
Jm24
Maf conversion
I have a 88 f-150 5.0l, I am wanting to do a maf conversion and was wondering if anyone made or has a maf conversion harness for sale.
Old Jan 28, 2021 | 04:02 AM
My4Fordtrucks's Avatar
My4Fordtrucks
There are companies that sell conversion kits. I am using a Ford Motorsports kit but you probably won’t be able to find one of them new anymore. There is a company ( Stinger Performance) that used to be on this forum. They are selling new computers that you can tune at home to work with your speed density system so there is no need to convert. Here is a current thread https://www.ford-trucks.com/forums/1...x-install.html
The question is why you want to do this conversion? What changes are you making to the engine? Speed density can cope with some things like headers instead of the stock manifolds
Old Jan 28, 2021 | 12:39 PM
Jm24's Avatar
Jm24
Plan is to run gt40 head, cam(not sure which yet), headers, and possibly intake as well.
Old Jan 28, 2021 | 01:03 PM
wwhite's Avatar
wwhite
No need to MAF swap for that.
I have 351w stock bottom end, long tube headers, 3881 intake, ported E7s, XE258HR-12 cam.
I will be putting on Edelbrock 60399 heads, once they ship(May 2021, weeks away!), and will not be doing MAF swap.
Runs using stock EEC-IV Speed Density(SD), small hunting idle issue(650-900rpm), doesn't miss a beat once the gas pedal is pressed.
Both MAF and SD systems can be tuned for optimal performance, really depends on budget .
If your specific engine build and vehicle use require MAF, there are many posts with success and also the pain stories of all the possible issues.
Some may say tuning SD is just as painful as doing the MAF swap.
Old Jan 28, 2021 | 01:06 PM
Conanski's Avatar
Conanski
Bottom line is if the engine combo does need tuning MAF is no longer required to get that.
Turbo__Charged_95
Oct 23, 2020 07:47 PM
MustangMabry
Aug 8, 2009 12:46 PM
IsItFast?
Nov 23, 2008 05:14 PM
96f350rcsrw460zf
May 5, 2005 01:59 PM
Leprakrotch
Feb 27, 2005 11:35 AM
