Bypass four-wheel drive control module
Old Jan 27, 2021 | 09:37 AM
Doug Britten's Avatar
Doug Britten
I have a 2002 Excursion XLT Limited 4x4 with 7.3 diesel. I recently lost 4 wheel drive and was able to identify the 4 wheel drive control module (or GEM, or body control module) as the issue. I would like to bypass the module completely and just use some toggle switches to control the motor on the transfer case. Any help would be appreciated.
Old Jan 27, 2021 | 01:50 PM
Doug Britten
Found Possible solution
If you have a better way, please share.
Old Jan 28, 2021 | 11:17 AM
bcrewcaptain's Avatar
bcrewcaptain
Exactly what I was thinking, same issue, same problem, I didn't dig into it yet, my only concern was ability to switch between high and low. I ordered a refurbed module off ebay and crossing my fingers. That hurt the wallet.
Old Jan 29, 2021 | 02:12 PM
EXSwap's Avatar
EXSwap
In this for the fix. I've not seen anyone actually be able to do a mod like this because the shifter on the transmission is not an on/off switch for each gear. It's a resistor if I remember correctly (not 100%) on that. In any case, the vehicle needs to see certain things like transmission in park, neutral, or drive/reverse; speed; and whether or not the brake is pressed (for low range). I suppose one could just power the shift motor using hot and ground, but being that it has 3 positions in the transfer case, I'm not sure how you'd do that. Very interested to see how you do this, so post up LOTS of pics!!
Old Oct 9, 2021 | 12:43 PM
NW7.3's Avatar
NW7.3
Anybody else do this?
Old Oct 9, 2021 | 02:09 PM
pirate4x4_camo's Avatar
pirate4x4_camo
You could bypass the stock system but would need to build a system to control the shift motor, i would think a Raspberry PI based controller to be be the simplest way to go about doing it electronically.
or switch to a mechanical system by building a shifter.
gcburkett
Nov 12, 2015 10:23 PM
ivplay
Nov 24, 2012 09:30 AM
WALJON
Nov 21, 2004 12:00 PM
