F350 Possible Electrical Problem? Please Help
Old Jan 26, 2021 | 05:06 AM
SquirrelyDan's Avatar
SquirrelyDan
Hey everyone, new to the site but I have a 2002 f350 super duty XLT, 5.0 engine that will stall out when I put the truck into drive and reverse. The same thing occurs too when I turn on the headlights, however, turning the interior lights on, along with the radio and heat vents on high, the truck does not stall. Originally, I had error codes for the mass air flow and something else and when I spoke to Friendly Ford to find out where the MAS was, they told me it was way under the manifold and so I had to take apart the whole manifold to realize where it's true location is. After I put everything back together...correctly the engine runs again and sounds a lot better, but I'm bamboozled as to why why it just keeps stalls when I put it into drive and or reverse. I think it may be caused by electrical something by having a heavy load on by changing into gears but I don't know. If anyone could offer me any advice, I'd really appreciate it.
Old Jan 26, 2021 | 06:41 PM
Fomoko1's Avatar
Fomoko1
Hi and welcome. I`m confused as I didn`t think that Ford put a 5.0 engines in an 02 F350.
Old Jan 26, 2021 | 06:48 PM
pbsdaddy's Avatar
pbsdaddy
Old Jan 26, 2021 | 07:44 PM
SquirrelyDan
Hey guys, sorry. The truck is a 5.4, not a 5.0. Thank you
Old Jan 26, 2021 | 07:47 PM
Fomoko1's Avatar
Fomoko1
A good thing we got that straightened out, repost in here: https://www.ford-trucks.com/forums/forum30/
Old Jan 29, 2021 | 01:07 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
What they said /\ /\ /\ /\ /\
Welcome aboard!
Old Jan 29, 2021 | 05:41 AM
seville009's Avatar
seville009
You don’t mention it, but the first step I would do is check your transmission fluid level.
Second step is make sure that you have a good, fully charged battery. Stick a new one in from another vehicle if possible.
Those are two simple things to at least check and rule out.
Ricardo Cortes
New Member Introductions
Aug 8, 2020 05:40 PM
Ryan.chand
Apr 15, 2020 09:10 PM
stremps
Feb 27, 2015 09:39 PM
fatryd
Jul 2, 2007 09:18 PM
