Sponsored by: Auxito
code P0174
Old Jan 25, 2021 | 02:23 PM
fritzie's Avatar
fritzie
code P0174
just had service engine soon lite pop on, put code reader on read P0174. May have vac. leak anybody else have this, my truck is 2000 4.2 89,000 mi.
Old Jan 25, 2021 | 07:37 PM
Stonedpony's Avatar
Stonedpony
What causes the P0174 code?
  • An air leak after the mass airflow (MAF) sensor, such as a torn intake boot, or bad intake manifold gaskets
  • A dirty or faulty mass airflow sensor
  • Faulty oxygen sensor
  • Incorrect fuel pressure
  • Leaking positive crankcase ventilation (PCV) valve
  • Clogged exhaust gas recirculation (EGR) Port
  • Leaking brake booster
Bank2 to lean which means the PCM is dumping fuel to that side to correct what it thinks is wrong.
Old Jan 26, 2021 | 07:52 AM
fritzie's Avatar
fritzie
code P0174
Thanks stonedpony i will go down that list i let u know what i find.
JoseFeli
Mar 4, 2011 09:52 PM
mr.fordneck
Dec 7, 2010 03:13 AM
