F250 reverse issue.
Strange symptom.
How did you verify the front was not engaging in reverse?
Lock the hubs in manually and try it.
Does it do it in 4 low too?
Also, disengage all traction control garbage, if you have that button on a 14? Thankfully my 11 has that disengage big brother button.
Tip: I leave my hubs locked-in most of the time in winter. Good for the U-joints. Do it once a month in summer for 10-20 miles.
Side note... if in fact, the front is not engaging at all...forward/reverse/4H/4L...
Vacuum leaks: You could have a leaking ESOF system on one or both sides.
A leak at the hub, or a bad vacuum line to the hub(s) etc. Usually, the HVAC system will act up as they operate off the same system at least it does in an 11.
By that I mean when you select vent, floor, defrost etc...do all of those positions work ok?
Strange symptom.
Michaelbute
03-16-2020 06:44 AM
Kamstutz
09-22-2012 10:47 AM
Mstewart
6.7L Power Stroke Diesel
07-10-2012 10:24 PM
