Front end work
Old Jan 20, 2021 | 04:45 PM
Icculus's Avatar
Icculus
Front end work
Hey y’all. Making a appointment for front ball joints, dust seals, leaf spring bushings.
anything else I should get done while it’s all apart?
I switched to manual hubs so not worried about the air tight seal replacement magig.
Old Jan 20, 2021 | 06:26 PM
brian42's Avatar
brian42
Veteran: Navy
If they haven't been changed out before I would put in new u-joints on the front axles since they're out.
Compared to the cost of the rest of the work (and the axles are already out) they are not that expensive and it would be good preventive maintenance. I recommend Spicer u-joints as they are the OEM supplier, fit perfectly, and are of better quality than most others.
Old Jan 20, 2021 | 08:41 PM
Greasemonkee's Avatar
Greasemonkee
I would get entire new leaf springs if you're going to that trouble, don't forget the new U bolts. While apart I would modify the hubs so you can grease them, change the track bar, drag link, lower tie bar and ball joints, steering damper, steering box with redhead unit, and may as well do the shocks while your in there, but you don't want to do just the front two so hit the rears and grab it all in one swipe. While you're at the rears might as well check the brakes, definitely do brake lines since the rubber is old and that's a safety item, and you'll need to flush out the brake system. Since you'll have it jacked up do the grease fitting mod on the driveshaft yoke, do the hutch mod, harpoon mod, change the rear diff fluid (better do the front too), and don't forget to check the diff vent tubes. Hit the transfer case and do a fluid change as well as the trans so you'll have it all covered. That does it for most of the outer components, let us know when you get done with that and we'll help you start on the engine.
Old Jan 20, 2021 | 08:47 PM
muhford's Avatar
muhford
If you're doing the ball joints have the U joints done too. Have them look at your steering and if anything is bad just change it all out. Drag link, tie rods, track bar, ect.
Old Jan 20, 2021 | 08:52 PM
udsuth78's Avatar
udsuth78
Needle bearings in hub assy. When they go they can take the stub shafts out too.
Old Jan 20, 2021 | 10:30 PM
hobohilton's Avatar
hobohilton
Is your truck 19 years old going on 200k miles? If so, what front end work has been done in the past?
Hobo
Old Jan 20, 2021 | 11:30 PM
Icculus's Avatar
Icculus
Hobo
its a 2002. Rust free. Only has 180k on it. I know for sure it needs new ***** joints and bushings. Didn’t get a lot of service records with it.
Old Jan 21, 2021 | 07:03 AM
hobohilton's Avatar
hobohilton
Get your truck to a Heavy Duty Truck Alignment shop (not a car shop) and listen to what they are telling you before throwing a lot of parts at it.... No need to have a truck with a "like new" front end when the engine and trans will be needing repairs. You have no service records so you must piece together the history of the entire truck. At 200k miles the PS will need routine maintenance, which is expensive if you can't do the work...Bring the entire truck along as a unit when it comes to maintenance... It will serve you well.
Hobo
Old Jan 21, 2021 | 09:24 AM
brian42's Avatar
brian42
Veteran: Navy
If you do consider new leafs I recommend Auto and Truck Springs (https://www.autoandtrucksprings.com/). They are top notch and I was very happy with them. If you ask for Junior he can help you with exactly what you are looking for and give you a quote if you are interested.
Among other things too. I have that t-shirt and it was expensive.
Always grease the needle bearing if you're pulling the hub off. It's a pain to remove but you can buy just the needle bearing. It's not listed as a separate part with Ford (you can only buy the whole hub assembly) but IIRC the part number is B2110.
Old Jan 21, 2021 | 11:14 AM
Icculus's Avatar
Icculus
I just got quoted 2500$ for all this work. I gotta find a bunch of overtime shifts that’s for sure
Old Jan 21, 2021 | 02:55 PM
muhford's Avatar
muhford
$2500 seems pretty high. I'd get some more estimates.
Old Jan 21, 2021 | 03:27 PM
udsuth78's Avatar
udsuth78
$2500 for what exactly, is thay parts and labor? I recommend sourcing your own parts. That will save you the shops markup plus you'll know what you have. Provided they actually install what you brought them
Old Jan 21, 2021 | 03:40 PM
brian42's Avatar
brian42
Veteran: Navy
You can request to see the old parts and packaging. They have to show you what they took off and the empty boxes of what you gave them.
Old Jan 21, 2021 | 05:26 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
I highly agree with this. When I haven't been able to do something myself (which is rare) I will buy the part needing to be installed and take it to a trusted shop.
Old Jan 21, 2021 | 05:28 PM
muhford's Avatar
muhford
If you can't trust a shop to supply quality parts can you really trust the shop?
