351W swap
Old Oct 25, 2003 | 07:48 PM
clean79150's Avatar
clean79150
351W swap
OK, I know several people have done the swap, so here is my question:
My truck is a 1979 F-150 4x4 with a manual transmission. I got the 300 six out, and have my 351W all ready to drop in.
The only problem I can see me running into is running the duel exhaust from the shorty headers. I don't know if I'll be able to squeeze the left side back through the driver's side, past the clutch linkage and around the transfer case, or would it be better to go under the oil pan and run the exhaust side by side down the passenger side and out the rear?
What have others done with the same set up? Any suggestions?
MODERATOR,
SORRY, I posted in the wrong forum. I mean't to post in the 1973 to 1979 Ford forum, can you move it???
Old Oct 25, 2003 | 09:56 PM
clean79150's Avatar
clean79150
MODERATOR/ADMINISTRATOR
Never mind, I posted it in the 73-79 forum. This one just needs deleted
Old Oct 26, 2003 | 05:56 AM
xfoa_chad's Avatar
xfoa_chad
i had a 77 with a 300 that i switched to 351w you will need the conversion headers from hedman they will run you about 350 bucks. i have a really good exhaust man here in southatlanta and he hooked me up right including flows and h-pipe contact Full Line Exhaust in atlanta for your components they are cheeper than jegs and summit you will need your part numbers when you cann them
the flows should side in opsit side out
xfoa_chad
www.xfoa.net founding member
Tbrooks09
Feb 19, 2014 11:07 PM
jetblack06
Feb 12, 2010 07:42 AM
fishin1976
Sep 18, 2003 09:17 PM
AMiller320
Sep 3, 2002 06:22 PM
aco
May 14, 2001 01:27 PM
