5.8 to 4.9 swap electrical nightmare
Okay, I got an engine bay wiring harness from an identical truck, but after hooking it all up the fuel pump does not prime when I turn the key. Everything else works as far as I can tell, including cranking the engine, blinkers, etc, but there is no fuel pump prime when the key is turned.
I figured it out. Yes, same year. The problem was I hadn't connected the inertial switch on the passenger kick panel. Now the fuel pump primes, engine cranks, but engine does not start. Possibly a ground wire or other connector in the dash that just isn't hooked up yet. We will see.
Okay, I was not expecting this, but when I pulled the plug from cylinder one and had my wife crank the engine, it did indeed have spark.
When I crank the engine nothing happens aside from that. There is no sputtering or attempting to start or combustion of any kind. Therefore, since I am getting spark and presumably air, it must be the case that I am not getting fuel, correct? The fuel pump primes when I turn the key, so it seems the culprit is that the injectors are not firing?
Received 1,028 Likes
on
EDIT: Also, I tried using my OBD-I scanner to see if there were any codes, and it didn't seem to be able to interact with the truck at all. I pressed the test button and it didn't display anything, though there were a few clicks in the engine bay.
Is the harness you have now all from one truck? If not what years and models are the sections from?
Do you have a 300 I6 PCM in it now?
on
114 - IAT out of range
116 - ECT out of range
552 - AIRB circuit fault
558 - EVR fault
636 - TOT out of range
654 - Trans selector not in park
Last one could be a problem, the temp sensors can be ignored because the engine/trans is cold and the other smog system codes won't prevent it from starting.
Ford is notorious for changing connector pinouts. The '96 harness is from a F250 isn't it? I just want to make sure neither of the donors were MAF.
What I'd suggest is taking apart the connector at C101 and check that there are the same number of wires on each side and that they are in the same pin positions. Wire colors won't match so don't worry about that.
558 - EVR fault
Well, I didn't have to count the number of pins. Many of them are not in the same place at all, which likely means the ones that are there aren't the same either. I can't find a pinout diagram for that year at all, and I have no interest at all in buying an EVTM for two years of trucks. 4.9L 1996 F-250s with GVWR 8501+ are as rare as can be, so I have very little chance of finding a compatible wiring harness, either.
on
We need somebody with an EVTM for either a '94 or '96 SD truck to post up a pinout for C101, that would make this a lot quicker.
But you will still have to get the multimeter out and trace some wires for the other side.
You can do this from scratch of course, get a pen and paper, multimeter or test light will work too.
Disconnect the battery.
Disconnect the PCM.
Break apart C101 and make a list of the pin locations that have wires, and then find what pins they go to at the PCM connector. The PCM pinout is all standard and never changed so then you know what signals are where so it's just a matter of matching up the other side, and these connectors come apart so the wires can be moved without doing any cutting or splicing.
Chances are most of the wires are in the correct locations and you only have to move a few, that means you're actually a lot closer than you might think.
Disconnect the PCM.
#29
Disconnect the PCM.
Disconnect the PCM.
#30
