Condensation on front cap
Old Jan 17, 2021 | 08:45 AM
RV_Tech's Avatar
RV_Tech
We are currently ensconced in south Florida. First time cold weather camping with North Star, but have winter camped in much colder weather in past in other rigs.
Front cap is drenched in the morning. Roof vent is full open when we sleep and inside temperature only in mid-50s, outside mid-40s small electric heater runs only intermittently, not using furnaces at all. Have to towel dry wall when waking.
Any ideas I haven’t thought of to reduce comdensation?
Old Jan 17, 2021 | 09:04 AM
HRTKD's Avatar
HRTKD
The furnace dries out my trailer more than my space heater does.
Old Jan 18, 2021 | 07:39 PM
senix's Avatar
senix
run the furnace at night.
Old Jan 18, 2021 | 07:51 PM
RV_Tech's Avatar
RV_Tech
Electric space heater accomplished the same thing. Both circulate and heat inside air.
Steve
Old Jan 18, 2021 | 07:53 PM
muhford's Avatar
muhford
Electric heaters don't treat the air, IE dry it out. A furnace will dehumidify the air.
Old Jan 18, 2021 | 07:58 PM
RV_Tech's Avatar
RV_Tech
So air passed over a heated metal element differs from air passed over a heat metal surface?
Old Jan 18, 2021 | 08:06 PM
senix's Avatar
senix
I guess the point being...additional vents that the heat is coming though vs one heater
Old Jan 18, 2021 | 08:12 PM
muhford's Avatar
muhford
I did a bunch of reading and I was slightly wrong Neither a furnace or an electric heater dry the air out. The furnace will likely keep it warmer thus keeping the air from condensing.
Old Jan 18, 2021 | 08:14 PM
RV_Tech's Avatar
RV_Tech
I don’t see how that changes the temperature of the air contacting the front cap which is what causes the condensation.
Usual suggestions normally involve using a dehumidifier during the winter months, which is not realistic or leaving a vent open which I already do. Ideally I would use a barrier such as a drape between the cap and warm air or a cap more heavily insulated would really help but again no way to do it. Having a cold cap is like blowing warm air on a cold metal surface.
Old Jan 18, 2021 | 08:15 PM
HRTKD's Avatar
HRTKD
At elevation in October we have to put a pot of water next to the furnace vent to try and keep up the humidity in the trailer.
Old Jan 18, 2021 | 08:18 PM
hobohilton's Avatar
hobohilton
You can find these at Camping World, Walmart, etc.
They help.
Hobo
https://www.campingworld.com/dri-z-a...E&gclsrc=aw.ds
Old Jan 18, 2021 | 08:19 PM
RV_Tech's Avatar
RV_Tech
Electric heater maintains same air temperature as furnace.
plenty of humidity here on Florida coast.
Old Jan 18, 2021 | 08:21 PM
RV_Tech's Avatar
RV_Tech
They help.
Hobo
I was wondering about those, but have never used them. will have to look into that. Have you used them?
Old Jan 18, 2021 | 08:34 PM
hobohilton's Avatar
hobohilton
I used them while full time RVing in a 4 Season Mountain Aire..... They help but condensation will form around the aluminum window frames. Many RV's have a built in vent to allow them to breath without loosing a lot of heat. I kept these in it even while in storage.
Hobo
Old Jan 18, 2021 | 08:49 PM
RV_Tech's Avatar
RV_Tech
Good to know. Thanks,
Steve
