2001 Super Crew no door locks working!
Old Jan 14, 2021 | 07:24 PM
brown2165's Avatar
brown2165
Angry 2001 Super Crew no door locks working!
I've searched and troubleshot this system for weeks and can't find the problem.
No voltage to the locks, replaced the remote key less/anti theft unit, nothing.
Need help troubleshooting the system?
Old Jan 14, 2021 | 07:29 PM
muhford's Avatar
muhford
Did you check your fuse box? Did you check for broken wires inside the door to pillar conduit?
Old Jan 14, 2021 | 07:39 PM
brown2165's Avatar
brown2165
Yes and yes
I have been through all the wiring checking for shorts and open wires.
No voltage at the switch, super crew goes through the anti theft and key less circuits also.
No voltage on black wire at switch!
Old Jan 14, 2021 | 07:40 PM
muhford's Avatar
muhford
Sometimes the wire breaks inside the insulation. You might just have to start tracing out wires.
Old Jan 15, 2021 | 06:08 AM
JWA's Avatar
JWA
Since this is an electrical issue posting in an engine forum isn't the best place to ask these questions.
Are you working from a Ford schematic? I'm guessing none of your door mounted controls operate the door lock system?
Old Jan 22, 2021 | 02:11 AM
cjensen68's Avatar
cjensen68
Probably not your issue. But I did have an issue where my door locks would not lock when I hit the button. I ended up breaking the plastic pieces that hold the actuator together open and wrapped the resistor in foil and reassembled. Then melted the plastic back together with a soldering iron. So far it's held for almost a decade.
matt_hackler
Dec 2, 2017 08:31 PM
dalej
Jul 29, 2017 07:16 PM
Super Duty Mike
Mar 16, 2011 01:17 PM
MP1
Electrical Systems/Wiring
Mar 13, 2005 04:53 PM
