I was fixin' to buy one and my friendly Ford parts man pointed that "Ya know, after it's on there a while....." it looks terrible. Which is the idea I guess, that the deflector takes the beating. But the ones I looked at required two sided tape (see post 3) or drilling holes on the underside of the hood.
I have one chip so far, but low miles, much of it long road trips. YMMV
I used to like formed ones. I couldn't stand the original "flags" that stuck up. I never had a problem with them coming loose. I used to put on window vents also but I don't smoke in my vehicles any longer and enjoy the reduced wind noise. However like already has been said the do look like crap after a while. I used Eagle 1 Nano polish on mine and the bugs came off easier plus it looked better for a longer period.of time.
TJ
In all seriousness though, most do more harm than good. The screws pull out or they rub paint off. Same with those “clear bras” that turn yellow and crack plus they’re almost impossible to remove and when you do, the paint has faded differently.
Rock chips are going to happen. No way around it, unless you don’t drive it.
I agree with that thought. I've seen bras and hood deflectors often cause damage that is worse than a few rock chips. Also, if you don't tailgate, you will get fewer chips.
I’ve had hood deflectors on my trucks for years. I’ve never had damage caused by the reflector. My other cars without deflectors all have paint chips on the hood lead edges.
The Ford OEM deflector on my F350’s do not make physical contact at all with the top of the hood or any painted surfaces. It’s attached using 6 screws that go into kit supplied either plastic or metal nut plates that are installed into factory pre-drilled holes under the hood. The deflector totally eliminates any rock chips to the lead edge of the hood. After 4 years it took a beating and there are witness marks on the deflector where rocks hit it.
It also does a good job of protecting the dead love bug acidic carcasses from etching the paint on the hood. See picture.
The ToughSkin deflector for the f150 is attached using 3m tape with no contact from the deflector to any painted surface.
Here are a few pictures of the one I’m considering for my F150 and picture of the one that I’ve been using on my 350s, before and after driving through love bugs.
I stopped running bug guards (aka hood deflectors) a few trucks ago. I don't know if they saved me from getting paint chips or not? But they always caused other paint damage by rubbing the paint off the edge of the hood or the 2 sided tape etching the paint. They also look like crap on newer trucks.
I haven't had any issues with paint chips on the hood since I stopped using bug guards. The only paint chips I've had were on the painted front bumpers.
That chrome one, don’t know what to say except rock chips look better. At least the one on the F150 doesn’t draw too much attention to itself. No love bugs where I live though. I bought a nice used F150 once that came from East Texas. The hood was ruined with dozens of paint etchings from those bugs. Got a good deal on it because of that.
Well they have a good supply of love bugs down there. They used to be real thick around Austin too.
TJ
I put AVS Bugflector IIs on all our trucks and never have any issues. I've never removed one so I don't know if they rub the paint off the lower edge of the hood but they are rock solid so I don't think they do. I just like the looks of them and will continue to buy them.
