Some 4WD vehicles with automatics will clunk or bang going into 4 low, due to transmission parts still spinning when the trans. is in neutral. If you're getting evil sounds just during gear changes, then something else is likely wrong. Change the fluid and see what's stuck to the magnet (if there is one) or comes out of the transfer case in the fluid. You're looking for larger metal shavings, rather than dust.
Yeah, I've gotten the grinding going into Park. I think it's just the gear reduction is able to keep things spinning in that brief period between R and P, combined possibly with a not-quite-strong-enough spring on the park pawl.
I pretty much exclusively use manual selections in low range. Trying to have an "automatic" in low is ridiculous and defeats the purpose as it'll try to run to OD as quickly as possible. Some of this is also just my rock crawling background but seriously "D" and low range don't mix.
And when you shift manually treat it like a bicycle: let up on the throttle, select the next gear, then get back into it once it's shifted. IOW YOU are the clutch
I gotta admit, I've never had an automatic 'bang' when using 4WD low...but then, I'm never moving fast enough to get out of 1st gear. If I'm in low range, I'm after torque to get something unstuck or get over something serious and don't WANT to move fast. If I need to be moving fast enough to shift gears, I'm going to use high range.
