F100 Styleside tail light question
Old Jan 13, 2021 | 02:19 PM
Nwhitesell's Avatar
Nwhitesell
2nd Gear
Greetings all,new to the forum. Can someone please offer some advice. I've had a 1959 Ford F100 stepside. I purchased a 6ft 59 styleside bed that will fit. My problem is the taillights, I have everything including the conical shaped housing and bulb. What wiring should I purchase if it's available or any thoughts to retrofit fit the bulb/wiring. Thank you all for taking time to read this and any help would be much appreciated, Nelson
Old Jan 13, 2021 | 06:58 PM
spurredon's Avatar
spurredon
Welcome to FTE. Any pics of the truck? You could just cut and splice where you need to using solder and shrink tubing. I have only had the styleside bed, are the wires shorter on the flareside? By the way step side is a Chevy term. There are complete taillight harness available if you want to go that route.
Thunderkiss1965
19
Jan 20, 2024 09:18 PM
harley7991
May 23, 2020 02:29 PM
1965F100(3onthetree)
15
Apr 18, 2020 04:02 PM
