1984 Ford F150 2WD Side Body Moulding
Old 01-12-2021, 04:03 AM
AFinley's Avatar
AFinley
AFinley is offline
Hello,
So, I have a 1984 Ford F150 2WD 4.9L 300 I6... I am getting close to installing the side body upper and lower trim moulding on my ground up restoration.
Question: How do you remove the vinyl insert in the middle of the lower body trim? I want to get them repaired, polished and anodized.
Thanks!
Old 01-12-2021, 10:24 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,759 Likes on 1,425 Posts
They are glued in. See if you can take a heat gun and get them apart. It may be difficult if the glue doesn't want to let loose.
Old 01-15-2021, 03:04 AM
AFinley's Avatar
AFinley
AFinley is offline
Thanks Franklin2. I am not sure they are glued in. I have a piece (lower drivers door) and its missing the black vinyl. There is no glue residue on it at all. It actually looks like they are pressed into the groove. I have another piece that I won't be using. I think I'll perform a little surgery on it to find out exactly how the vinyl is affixed to the aluminum.
Good looking out though....
Have a nice day!
blueoval65
31
12-09-2020 09:16 PM
broktruk
12-22-2019 03:30 PM
firemarshalmike
02-21-2014 07:45 AM
mitch01
Paint & Bodywork
01-16-2008 07:05 PM
Quick Reply: 1984 Ford F150 2WD Side Body Moulding
