Motor opinions...
Old Jan 11, 2021 | 09:42 PM
AnotherChef's Avatar
AnotherChef
Motor opinions...
I'm looking at a 53 Ford Customline that has a flathead in it... I have a 79 parts truck with a 302 in it....
Which would be the better motor to build for decent HP/torque?? Ill go with Edelbrock EFI (again) and not sure on heads yet...
Old Jan 11, 2021 | 09:45 PM
hobohilton's Avatar
hobohilton
I would go with the 302.... Many more options and availability on parts.
Hobo
Old Jan 12, 2021 | 01:32 AM
85e150's Avatar
85e150
But a '79 302 needs to be gone through and modified to make any power.
Old Jan 12, 2021 | 01:49 AM
buckin69bronco's Avatar
buckin69bronco
The 302 is a more efficient motor for sure but flatheads are so cool.
what’s your intended use for the truck? If it’s just a sunny day weekend truck I’d build the flathead. It won’t be that far behind the 302 in power or mileage to really matter.
If you are not interested in the flat head I wouldn’t actually spend my time to swap in the 302 especially if you plan to go EFI. I’d go build a 351w with a striker kit in it and you could even get one from a 96-97 that is factory efi.
Old Jan 12, 2021 | 10:00 AM
meangreen92's Avatar
meangreen92
If the '53 is going to stay original-looking, I'd go for the flathead, but if you're going full custom, then the 302 will be a lot less inappropriate.
Old Jan 12, 2021 | 10:49 AM
symonds86's Avatar
symonds86
I agree what are you goals for the car. What trans options are you thinking. The 302 is about 100 lbs lighter stock and could save more with aluminum heads. Could also do a 331 or 347 stroker with the 302. But if it a stock ish car the flathead imo would fit the vib better, and if you build more power any weak links will start showing themselves soon after.
Old Jan 12, 2021 | 10:58 AM
HoustonDave's Avatar
HoustonDave
ain't nothin' sounds like a flathead. More parts and such available for a 302 but why screw up a good '53 with a dirt common modern motor? You have an ultra-cool truck... the cool factor of the flathead is about 20X a 302. My old-fashioned opinion.
Old Jan 12, 2021 | 01:25 PM
65f100_352's Avatar
65f100_352
Efi the flathead, you can make it sneaky and you would have to have a close look to see its fuel injected.. better fuel mileage and power from a classic mill, hard to beat
Old Jan 12, 2021 | 03:08 PM
caravaggio2000's Avatar
caravaggio2000
I'd keep the flathead. It belongs there. You could be super cool and do something like this though...
Old Jan 12, 2021 | 06:10 PM
SDDL-UP's Avatar
SDDL-UP
1979 302 "modern motor" have me a chuckle!
peckhamjusten
Dec 31, 2008 10:39 AM
davidsca
Jun 11, 2006 06:46 PM
fordfan302
Mar 18, 2006 06:30 PM
Justin89
Nov 24, 2002 07:12 PM
DFred40
1997 - 2003 F150
Aug 25, 2002 03:54 AM
