2019-FORD F250 XL 6.7 Diesel -Recently disconnected both batteries then re-connected both. I had problems with my heating and air control would not power-up? Now my day lites won't shut off and my HVAC still doesn't work. Any help would be highly appreciated.
Maybe DRL is a default so when power was pulled it went to that ? On my "20" I can select or deselect it in the trucks menu options off the center stack screen I believe. I'm guessing you killed power hoping to reset something if that was the problem with the heat. If it were my truck and not under warranty I would see if there was power at the blower motor first that would tell you a lot. Then maybe give it some to see if it turns. Last trouble shoots I did were maybe 10 or so years ago so maybe I don't know. Keep us posted I know I like to follow a fixed it story as do others.
DRL means? Sorry for being new. Another thing I noticed that the day lites would flicker whenever I’d walk by. Could this be an alarm issue?
