Weird idle issue
Old Jan 7, 2021 | 10:12 AM
johnmallen78's Avatar
johnmallen78
3rd Gear
Weird idle issue
So I have a 1987 F150 with a 4.9l. It has a weird issue that just recently popped up where after I have driven it for a bit and come to a stop (stop light or stop sign) it will idle normally for about 10 seconds and then it drops to almost 500 rpm then back up to about 750 and cycles like that for about a minute then finally stabilizes at 750. Things I have already done:
Cat delete with Y-Pipe and O2 sensor in place
New IAC
New EGR
New MAP
Just had the engine de-sludged because the previous owner apparently didn't believe in changing his oil...but this was happening prior to that.
Checked for vacuum leaks and replaced any leaky hoses
It acts like an IAC issue but having a new one on there I'm confused...
Old Jan 7, 2021 | 11:05 AM
R&RFord's Avatar
R&RFord
Is it just responding to your AC compressor?
Run codes.
Old Feb 27, 2021 | 11:36 PM
andywould90's Avatar
andywould90
i would test the tps does it idle up when cold and drop down once it reaches warmer temp
Old Mar 5, 2021 | 06:23 PM
OBSADDICT's Avatar
OBSADDICT
Trailering
Had a similar issue
Hey,
I had a similar issue with my truck, a 93 5.0. The tps and cleaned EGR that solved it. Imho, these trucks have too much crap on em to diagnose easily. Have you pulled codes yet?.
fordboy97
Nov 12, 2015 01:28 PM
2001supercrewf150
Modular V8 (4.6L, 5.4L)
Mar 25, 2010 04:23 PM
wolverine382
1997 - 2003 F150
Apr 21, 2009 10:13 PM
Jamar
Mar 17, 2006 02:51 PM
tHeCoS
Nov 8, 2004 07:57 AM
