Sponsored by: Real Truck
speedo intermittent
Old Oct 25, 2003 | 08:36 AM
edstoner's Avatar
edstoner
speedo intermittent
I was hoping mabye someone has seen the following problem. Just yesterday my speedometer stopped working and the overdrive "off" light on the end of the shift lever started to flash. I shut the truck off and back on and everything was back to normal. Now it seems like every other time I start the truck the problem is back. What I mean is that if the problem starts again I shut the truck off and restart it and it's gone. But next time I start it the speedo doesn't work and the overdrive off light will start to flash. I looked in the owners manual but couldn't find anything about a speedometer relay. I've never seen this before but to me it seems like a relay is getting ready to go bad. When the speedometer stops working everything else works fine, including the tachometer. The only other indication is that the overdrive light flashes. Thanks for any input in helping me solve this problem. 99 f350 SD PSD
Old Oct 25, 2003 | 09:12 AM
GAV10's Avatar
GAV10
Rear differential speed sensor. Two bolts one electrical connector. About 20 bucks and 20 minutes. Very common problem on SD's and F-150's.
Mark
Old Oct 25, 2003 | 06:11 PM
edstoner's Avatar
edstoner
Thanks for the feedback. I got the part from the dealer and will crawl under the truck tomorrow But looking at the part it looks like cake to change. Thanks again!
Old Oct 25, 2003 | 08:48 PM
GAV10's Avatar
GAV10
Your welcome. It is easy. If your truck is a 4x4 you won't even have to jack it up, just slide right under.
Good luck
Mark
blueoval65
May 3, 2020 02:03 PM
dfarland
Sep 23, 2010 03:06 PM
Stickz
16
Jul 27, 2009 10:31 PM
Insane Wheeler
Nov 24, 2008 11:36 PM
